Building my own mp3 player in MMBasic
Hi there,
I’m trying to build my own MP3 player.
Everything works fine as long as I know the list of titles in advance.
However, when dealing with unknown folders, I have a question:
How can I store the filenames from a folder into an array in MMBasic?
I’ve tried using ChatGPT and Copilot, but neither provided a working solution.
Try the PicoMite manual. AI is kinda useless for esoteric information right now.
Here’s a simple code snippet.
dim file$(25)
f1=1
f$=Dir$("*.mp3",FILE)
Do While f$<>""
   file$(f1)=f$
   f$=Dir$()
   f1=f1+1
Loop
wow thank you very much - it works !!
here is my state of work :slight_smile:
the Bitrate of the mp3 is importent for the correct lenght suggestion
in this code i used a 320kbit mp3
The left and right arrow switch trough the tracks
'music
x=1
y=0
tmp$=""
Dim mp3$(100)
f1=1
Do While f$<>""
   mp3$(f1)=f$
   f$=Dir$()
   f1=f1+1
Loop
Do while x <  f1
  CLS
  Print "########################"
  Print "####### SiD Music ######"
  Print " "
  Print mp3$(x) + ".mp3"
  Open mp3$(x)+".mp3" For input As #1
  y = Lof(1)
  Close #1
  Play mp3 mp3$(x)
  z=Cint(((y*8)/320000))
  Do While z > 0
     k$ = Inkey$
    If k$ <> "" Then
      Select Case Asc(k$)
        Case 131: Play stop
                  z=0
        Case 130: Play stop
                  x = x-2
                  z=0
        Case 32: Play stop
      End Select
    End If
    Pause 100
    z=z-1
    min = Int(z / 60)
    sec = z Mod 60
    If sec < 10 Then
      tmp$ = Str$(min)+":0"+Str$(sec)+"  "
    Else
      tmp$ = Str$(min)+":"+Str$(sec)+"   "
    EndIf
    Print @(0,60) tmp$
    Pause (900)
   Loop
  x=x+1
Loop
I made a few changes to your mp3 player, so I’m posting the code here in case you or others are interested.
  1. Reads .mp3 files from b:/mp3/ (to avoid cluttering the root directory)
  2. Randomizes the list of mp3 files (because listening in order may be boring)
  3. “space” stops the player and exits (before it just muted it but kept going)
I also found out that OPTION CPUSPEED 200000 is required with the PI Pico 2w, in case others get an error about insufficient CPU speed.
'music
x=1
y=0
tmp$=""
Dim mp3$(100)
Drive "b:"
Chdir "b:/mp3"
f1=1
Do While f$<>""
   mp3$(f1)=f$
   f$=Dir$()
   f1=f1+1
Loop
Randomize
For i=1 To f1 - 1
   k$ = mp3$(i)
   j = Rnd(f1 - 1) + 1
   mp3$(i) = mp3$(j)
   mp3$(j) = k$
Next
Do While x <  f1
  CLS
  Print " "
  Print mp3$(x)
  Open mp3$(x) For input As #1
  y = Lof(1)
  Close #1
  Play stop
  Pause 1000
  Play mp3 mp3$(x)
  Do While z > 0
     k$ = Inkey$
    If k$ <> "" Then
      Select Case Asc(k$)
        Case 131: Play stop
                  z=0
        Case 130: Play stop
                  x = x-2
                  z=0
        Case 32: Play stop
                 x=f1
                 z=0
      End Select
    End If
    Pause 100
    z=z-1
    min = Int(z / 60)
    sec = z Mod 60
    If sec < 10 Then
    Else
    EndIf
    Print @(0,60) tmp$
    Pause (900)
   Loop
  x=x+1
Loop
Enjoy!
Hi :slight_smile:
Thanks for your reply. I reworked my code myself a few days ago and added a path variable for the music folder too. I added a Cover view and a better refresh (with no blinking while changing tracks).
Furthermore, I don’t like random music shuffling, but I like to have the choice, so I take your random function as a commentary - so everybody can decide to use it or not.
You are right here
adcockm
said you can go up to 380000 with a Pico 2 - and he is right.
My new Code with
'music
x=1
y=0
tmp$=""
Dim mp3$(100)
path$ = "b:\music\"
f1=1
f$=Dir$(path$ + "*.mp3",FILE)
cover$ = "cover.bmp"
Do While f$<>""
   mp3$(f1)=path$+f$
   f$=Dir$()
   f1=f1+1
Loop
'Randomize
'For i=1 To f1 - 1
'   k$ = mp3$(i)
'   j = Rnd(f1 - 1) + 1
'   mp3$(i) = mp3$(j)
'   mp3$(j) = k$
'Next
CLS
On error skip 1
Load image(path$ + cover$)
Do While x < f1
  Print @(0,40) mp3$(x)
  y = Lof(1)
  Close #1
  Play mp3 mp3$(x)
  Do While z > 0
     k$ = Inkey$
    If k$ <> "" Then
      Select Case Asc(k$)
        Case 131: Play stop
                  z=0
        Case 130: Play stop
                  x = x-2
                  z=0
        Case 32: Play stop
                        CLS
	                x=f1
                        z=0
      End Select
    End If
    Pause 100
    z=z-1
    min = Int(z / 60)
    sec = z Mod 60
    If sec < 10 Then
    Else
    EndIf
    Print @(0,60) tmp$
    Pause (900)
   Loop
  Play stop
  x=x+1
Loop
And a new version.
Now you can choose to shuffle or not from the program :slight_smile:
Press 1 toggle between shuffle and no shuffle - the choice is saved in a txt file in the music folder.
To avoid the false length calculation, a bitrate.txt file with 1 line (e.g. 320000) for the bitrate of the music folder can be used.
Next step will be to shown the folder structure to choose the music folder from the app.
'music
x=1
y=0
tmp$=""
Dim mp3$(100)
path$ = "b:\music2\"
shuffle$ = "false"
bitrate$ = "320000"
f1=1
Do While f$<>""
   mp3$(f1)=path$+f$
   f$=Dir$()
   f1=f1+1
Loop
On error skip 3
Open (path$ + "bitrate.txt") For input As #1
Line Input #1, bitrate$
Close #1
On error abort
On error skip 3
Open (path$ + "shuffle.txt") For input As #1
Line Input #1, shuffle$
Close #1
On error abort
If shuffle$ = "true" Then
 doshuffle
EndIf
Sub doshuffle
 Randomize
 For i=1 To f1 - 1
 k$ = mp3$(i)
 j = Int(Rnd*(f1 - 1)) + 1
 mp3$(i) = mp3$(j)
 mp3$(j) = k$
 Next
End Sub
Sub unshuffle
  f1=1
  Do While f$<>""
    mp3$(f1)=path$+f$
    f$=Dir$()
    f1=f1+1
  Loop
End Sub
Sub writeshuffle
 Open path$ + "shuffle.txt" For OUTPUT As #1
  Print #1, "false"
Print @(0,36)"########################"
 shuffle$ = "false"
 unshuffle
 Else
  Print #1, "true"
Print @(0,36)"###############shuffle##"
  shuffle$ = "true"
  doshuffle
 EndIf
 Close #1
End Sub
CLS
On error skip 1
On error abort
Do While x < f1
 Else
 EndIf
 Print @(0,55) mp3$(x) + "             "
 Open mp3$(x) For input As #2
 y = Lof(2)
 Close #2
On error skip 1
 Play mp3 mp3$(x)
On error abort
 z=Cint(((y*8)/Val(bitrate$)))
 Do While z > 0
  k$ = Inkey$
 If k$ <> "" Then
  Select Case Asc(k$)
  Case 131: Play stop
     z=0
  Case 130: Play stop
     x = x-2
     z=0
  Case 32: Play stop
     CLS
     x=f1
     z=0
  Case 49
     x=0
     writeshuffle
  End Select
 End If
    Pause 100
    z=z-1
    min = Int(z / 60)
    sec = z Mod 60
    If sec < 10 Then
    Else
    EndIf
    Print @(0,65) tmp$
    Pause (900)
   Loop
  Play stop
  x=x+1
Loop
I read the manual :wink: and found the interrupt for MP3 Playback.
  • no Bitrate Infos are needed
  • skip small files (i have some ._filename.mp3 in some folders)
'music
x=1
y=0
tmp$=""
Dim mp3$(100)
path$ = "b:\music3\"
shuffle$ = "false"
f1=1
Do While f$<>""
   mp3$(f1)=path$+f$
   f$=Dir$()
   f1=f1+1
Loop
On error skip 3
Close #1
On error abort
 doshuffle
EndIf
Sub doshuffle
 Randomize
 For i=1 To f1 - 1
 k$ = mp3$(i)
 mp3$(i) = mp3$(j)
 mp3$(j) = k$
 Next
End Sub
Sub unshuffle
  f1=1
  Do While f$<>""
    mp3$(f1)=path$+f$
    f$=Dir$()
    f1=f1+1
  Loop
End Sub
Sub nextSong
playSong$ = "false"
End Sub
Sub writeshuffle
  Print #1, "false"
 shuffle$ = "false"
 unshuffle
 Else
  Print #1, "true"
  shuffle$ = "true"
  doshuffle
 EndIf
 Close #1
End Sub
CLS
On error skip 1
On error abort
Do While x < f1
 Else
 EndIf
 y = Lof(2)
 Close #2
 On error skip 1
 Play mp3 mp3$(x) ,nextSong
 On error abort
 playSong$ = "true"
  Do While playSong$ = "true" and y > 10000
  k$ = Inkey$
 If k$ <> "" Then
  Select Case Asc(k$)
  Case 131: Play stop
     z=0
  Case 130: Play stop
     x = x-2
     z=0
  Case 32: Play stop
     CLS
     x=f1
     z=0
  Case 49
     x=0
     writeshuffle
  End Select
 End If
    Pause (100)
    z=z+1
    min = Int(z / 60)
    sec = z Mod 60
    If sec < 10 Then
    Else
    EndIf
    Print @(0,65) tmp$
    Pause (900)
   Loop
  Play stop
  z=0
  x=x+1
Loop
I used some of your code to get me going. Now on my second version. Very simple but the UI worked out nice. Handles up to 99 MP3’s and you can flick through pages of 20 tracks easily. Hope to add a shuffle feature next.
'mp3 Player by Paul Walsh
'set up directory name music on sd
'add up to 99 mp3’s
'add mp3 with title max length 36
'work in progress. Hope to add more
Dim mp3$(200)
Dim STRING k$
Dim STRING playing$
playing$=“1”
k$=“1”
c1=1
f1=1
p1=1
x=120
y=260 'Vertical menu position
listsize=20 'Tracks per screen
listnumber=1
Sub nextsong
playsong$=“false”
playing$=k$
End Sub
CLS
path$ = “b:\music"
'Save all .mp3 files in array
f$=Dir$(path$ + “*.mp3”,FILE)
Do While f$<>”"
slength=Len(f$)
slength=slength-4
f$=Left$(f$,slength)
mp3$(f1)=f$
f$=Dir$()
total=f1
f1=f1+1
Loop
newlist:
p1=1
f1=1
'Play Stop
CLS
'Print track list
If listnumber>lastlistnumber Then f1=f1+((listnumber-1)*listsize)
If listnumber<lastlistnumber Then f1=f1+((listnumber-1)*listsize)
'Check if 1st page
If f1<1 Then f1=1:listnumber=1
'Check if last page
If f1>total Then
listnumber=lastlistnumber
f1=((listnumber-1)*listsize)
EndIf
Do While p1<listsize+1 And mp3$(f1)<>“”
Print f1 ,“- “;
Print mp3$(f1)
p1=p1+1
f1=f1+1
c1=p1 'Passes p1 value out of Sub
Loop
Chdir path$
k$=“1”
Colour RGB(WHITE), RGB(BLACK)
Print @(x,y) “Playing “;playing$
Print @(0,y+27); “(1 -”;
Print @(30,y+27) f1-1;”)”,””
Print @(74,y+27) “(s)STOP”
Print @(142,y+27) “(n)NEXT”
Print @(210,y+27) “(u)UP”
Print @(260,y+27) “(d)DOWN”
Colour RGB(GREEN), RGB(BLACK)
Do While Val(k$)<total+1
On Error skip 1
Play mp3 mp3$(Val(k$)),nextsong
On Error abort
jump2:
playsong$=“true”
last$=Str$(Val(k$)+1)
Do While playsong$=“true”
skip:
k$=Inkey$
If k$<>“” Then
If Val(k$)>0 Then Pause 1200:u$=Inkey$:k$=k$+u$
If Val(k$) >= f1 Then GoTo skip
If k$=“s” Then GoTo stop
If k$=“n” Then playsong$=“false”:k$=Str$(Val(playing$)+1)
If k$=“d” Then
lastlistnumber=listnumber
listnumber=listnumber+1
GoTo newlist
EndIf
If k$=“u” Then
listnumber=listnumber-1
GoTo newlist
EndIf
If Val(k$) = 0 Then GoTo skip
'Check if (n) NEXT has been selected
'on the last track in list
'If Val(k$)>f1 Then k$=“1”
If Val(k$)>2 And Val(k$)<10 Then Pause 1000
Play Stop
Print @(x,y) " "
Print @(x,y) “Playing “; k$
EndIf
If k$=”” Then k$=last$
Loop
Play stop
d=Val(k$)-1
d=d+1
k$=Str$(d)
Print @(x,y) " "
Print @(x,y) "Playing "; k$
Loop
stop:
CLS
Chdir “..”
End
