Calculator app.
Navigation with UP, DOWN, LEFT, RIGHT arrows
ENTER selects the box
BACK clears the window and the ANS.
ESC will exit the code
Still work in progress. To do next:
- error management
- accept longer expressions. Right now, you have to type the full expression ex.: sqr(5)*sqr(5). In the future, we should use the function boxes as a shortcut.
- adding new functions, as needed
' Define colors
bl=RGB(blue)
gr=RGB(green)
bk=RGB(black)
wt=RGB(white)
gy=RGB(gray)
rd=RGB(red)
' UI box dimensions
DIM x(3), y(2)
w=73
h=68
x(0)=10 : x(1)=85 : x(2)=160 : x(3)=235
y(0)=110 : y(1)=180 : y(2)=250
' Define function labels
DIM fun$(2,3)
fun$(0,0)="e" : fun$(0,1)="pi" : fun$(0,2)="%" : fun$(0,3)="ANS"
fun$(1,0)="log" : fun$(1,1)="ln" : fun$(1,2)="x^y" : fun$(1,3)="x!"
fun$(2,0)="sqrt" : fun$(2,1)="sin(x)" : fun$(2,2)="cos(x)": fun$(2,3)="tg(x)"
' Draw initial UI
CLS
BOX 0,0,320,320,,bk,bk
BOX 10,10,298,80,2,rd,wt
FOR r=0 TO 2
FOR c=0 TO 3
BOX x(c),y(r),w,h,2,wt,gy
TEXT x(c)+w/2,y(r)+h/2,fun$(r,c),"CM",,,wt,gy
NEXT
NEXT
' First input exactly
COLOR rd, wt
TEXT 20,60,">","LT",,,rd,wt
INPUT "", input$
ANS = EVAL(input$)
r=-1 : c=0 ' r=-1 means input box is selected
editing%=1
' Helpers
SUB HighlightHeader(sel%)
IF sel% THEN
BOX 10,10,298,80,2,bl,wt
COLOR rd,wt
TEXT 20,60,STR$(ANS),"LT",,,rd,wt
ELSE
COLOR rd,wt
ENDIF
END SUB
SUB EditInput()
COLOR rd,wt
INPUT "", input$
END SUB
' Selection logic
DO WHILE editing%
IF r>=0 THEN
BOX x(c),y(r),w,h,2,bl,gy
TEXT x(c)+w/2,y(r)+h/2,fun$(r,c),"CM",,,bl,gy
ELSE
HighlightHeader(1)
ENDIF
a$=INKEY$
IF a$<>"" THEN
IF r>=0 THEN
ELSE
HighlightHeader(0)
ENDIF
SELECT CASE a$
CASE CHR$(130) : IF r>=0 AND c>0 THEN c=c-1 ' Left
CASE CHR$(131) : IF r>=0 AND c<3 THEN c=c+1 ' Right
CASE CHR$(128) ' Up
IF r=0 THEN r=-1
IF r>0 THEN r=r-1
CASE CHR$(129) ' Down
IF r=-1 THEN r=0 ELSE IF r<2 THEN r=r+1
CASE CHR$(27) : editing%=0 ' ESC
CASE CHR$(8) ' Backspace: clear window and reset ANS
ANS=0
COLOR rd,wt
TEXT 20,60,"0","LT",,,rd,wt
CASE CHR$(13) ' Enter
IF r=-1 THEN
' Prompt for new input, update ANS, and display ANS
EditInput
IF LEN(input$) > 0 THEN
ANS = EVAL(input$)
ENDIF
COLOR rd,wt
ELSE
ON ERROR SKIP
SELECT CASE fun$(r,c)
CASE "e" : ANS=EXP(1)
CASE "pi" : ANS=PI
CASE "%" : ANS=ANS/100
CASE "ANS" : ANS=ANS
CASE "log" : ANS=LOG(ANS) / LOG(10)
CASE "ln" : ANS=LOG(ANS)
CASE "x^y"
EditInput
IF LEN(input$) > 0 THEN ANS=ANS^EVAL(input$)
CASE "x!" : ANS=Factorial(ANS)
CASE "sqrt" : ANS=SQR(ANS)
CASE "sin(x)" : ANS=SIN(ANS)
CASE "cos(x)" : ANS=COS(ANS)
CASE "tg(x)" : ANS=TAN(ANS)
END SELECT
IF MM.ERRNO <> 0 THEN
COLOR rd,wt
TEXT 20,60,"Error: " + STR$(MM.ERRNO),"LT",,,rd,wt
MM.ERRNO = 0
ELSE
COLOR rd,wt
ENDIF
ENDIF
END SELECT
ENDIF
PAUSE 20
LOOP
COLOR gr,bk
CLS bk
' Factorial function
FUNCTION Factorial(n)
IF n < 0 THEN
Factorial = 0
ELSEIF n = 0 OR n = 1 THEN
Factorial = 1
ELSE
Factorial = 1
FOR i = 2 TO n
Factorial = Factorial * i
NEXT
ENDIF
END FUNCTION
