I can’t connect to free wifi. about half the time when i try it loads and then just disappears and the other half it give me a bad password error message. no problem with private wifi. if i go into info it says the ip is not connected
Well the problem is, if that most free WiFi need you to log on a webpage, I doubt that the GAmeShell have any facility for that
Not all free WiFi’s need that. Make a hotspot on your phone instead. Or try another free WiFi.
Sure, but my phone hotspot have a password
(don’t want other people to get access to it!) and it’s not free
(I rephrase my original answer as it is “most” not all and you are right about that)
Yeah if the free wifi (Like mcdonalds) has a captive portal you need to accept the EULA in order to access to the wifi.
i have my wifi split in half with a private network and a guest network i can only connect to the private one
there is no captive portal because it is my personal wifi. a phone hotspot would work good idea!
