Circuit Python Support
Sorry for making a new forum but I’m the last replier in CircuitPython with Pico 2 W (and I’ve hit the limit of replies)
But if anyone is still interested in Circuit Python, you could implement @BlairLeduc’s drivers
I’ve done so in MicroPython and the syntax isn’t too different
https://github.com/jblanked/Picoware/blob/main/src/MicroPython/picoware_lcd/picoware_lcd.c
Using C modules would fix this:
since the C module can handle text
and images
After a cursory look, the problem with CircuitPython is that it wasn’t written to have the REPL run on the device except through the serial port and there was no way I could see to change this.
It is also quite the bear to create a new port.
That’s actually a great point. I’ve only used it through Thonny so far, but I did notice that when using PicoDVI, the serial/REPL would display on the TV.
Circuit Python puts the REPL on the device by initializing the screen as a busdisplayio, for example here for the M5Stack Cardputer circuitpython/ports/espressif/boards/m5stack_cardputer/board.c at main · adafruit/circuitpython · GitHub
