Using the side pins of the picocalc, I successfully played MIDI sounds on mmbasic.
I configured the GP28 pin as a software UART output, sending a 31250bps signal to the MIDI Synth module. While GP28 could likely be assigned to the hardware UART, I abandoned that idea since UART1 was already in use for the serial console via another pin.
(Is there a way to use the hardware UART?)
The Synth module is Kinoshita Laboratory’s “MIDI-guy” (the red board on the left, equipped with SAM2695). I plan to integrate this and force the audio output to the speaker.
Thank you!
I’ve seen tracker apps before, but I’ve never actually used one myself…
For now, I’ve managed to parse and play SMF Format 0 .MID files.
Since I’m handling wait times with `pause`, game music with lots of messages happening at once ends up sounding slow, but piano pieces play just fine.
Using Settick instead of Pause improved the tempo drift somewhat.
However, perhaps because I’m using software UART, the tempo still slows down as the number of notes increases.
I tried to use hardware UART to increase processing speed. But I couldn’t disable the serial console function (which connects to a PC terminal software via USB serial) that occupies it.
This is proving quite difficult…
