Curious about the MIPI-CSI connector on the default EXT board. I’ve done some searching here, Reddit etc - did anyone successfully connect a camera module via this connector?
I had tried to connect a Raspberry Pi Zero camera via mine and yatli’s (forgot to credit the MVP
) cartridge system but I failed miserably at the device tree.
I did get a few more video devices, but they all didn’t play well with V4L.
Signal integrity through the connector could also have been an issue.
I did however match the impedance of the differential lines as well as I could.
Here’s the dts for anyone interested.
DTS for camera
/dts-v1/;
/plugin/;
#include <dt-bindings/clock/rk3399-cru.h>
#include <dt-bindings/interrupt-controller/arm-gic.h>
#include <dt-bindings/power/rk3399-power.h>
/*compatible = "brcm,bcm2835";*/
compatible = "rockchip,rk3399";
fragment@0 {
target-path = "/";
__overlay__ {
isp0: isp0@ff910000 {
compatible = "rockchip,rk3399-cif-isp";
reg = <0x0 0xff910000 0x0 0x4000>;
interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru SCLK_ISP0>,
<&cru ACLK_ISP0>, <&cru ACLK_ISP0_WRAPPER>,
<&cru HCLK_ISP0>, <&cru HCLK_ISP0_WRAPPER>;
clock-names = "clk_isp",
"aclk_isp", "aclk_isp_wrap",
"hclk_isp", "hclk_isp_wrap";
power-domains = <&power RK3399_PD_ISP0>;
iommus = <&isp0_mmu>;
status = "okay";
port {
#address-cells = <1>;
#size-cells = <0>;
/* mipi */
isp0_mipi_in: endpoint@0 {
reg = <0>;
data-lanes = <1 2>;
remote-endpoint = <&dphy_rx0_out>;
fragment@2 {
target = <&isp0_mmu>;
__overlay__ {
status = "okay";
fragment@10 {
target = <&i2c2>;
__overlay__ {
#size-cells = <0>;
status = "okay";
ov5647: ov5647@36 {
compatible = "ovti,ov5647";
reg = <0x36>;
status = "okay";
pwdn-gpios = <&gpio0 29 1>, <&gpio0 28 1>;
/*clocks = <&ext_cam_clk>;*/
/*clocks = <&cru SCLK_TESTCLKOUT1>;*/
/*assigned-clock-rates = <25000000>;*/
clocks = <&cru SCLK_CIF_OUT>;
clock-names = "xvclk";
assigned-clocks = <&cru SCLK_CIF_OUT>;
rotation = <0>;
port {
cam_out: endpoint {
remote-endpoint = <&csi1_ep>;
clock-lanes = <0>;
data-lanes = <1 2>;
clock-noncontinuous;
link-frequencies =
/bits/ 64 <297000000>;
fragment@3 {
target = <&mipi_dphy_rx0>;
__overlay__ {
compatible = "rockchip,rk3399-mipi-dphy-rx0";
clocks = <&cru SCLK_MIPIDPHY_REF>,
<&cru SCLK_DPHY_RX0_CFG>,
<&cru PCLK_VIO_GRF>;
clock-names = "dphy-ref", "dphy-cfg", "grf";
power-domains = <&power RK3399_PD_VIO>;
#phy-cells = <0>;
status = "okay";
ports {
#size-cells = <0>;
port@0 {
#size-cells = <0>;
reg = <0>;
csi1_ep: endpoint@0 {
#size-cells = <0>;
reg = <0>;
remote-endpoint = <&cam_out>;
clock-lanes = <0>;
data-lanes = <1 2>;
port@1 {
reg = <1>;
dphy_rx0_out: endpoint {
data-lanes = <1 2>;
remote-endpoint = <&isp0_mipi_in>;
__overrides__ {
rotation = <&ov5647>,"rotation:0";
