Error : Not enough Heap memory
I can create a file on drive b: with EDIT “test.bas”
When pressing F1 it saves the file to SD card.
When editing the file again I get the error on pressing F1: Error : Not enough Heap memory
This only happens on drive b:. On drive A: everything is fine.
I’m using PicoMite V6.00.01
This seems to be a similar issue to the issue reported in "Not enough memory" when saving from editor in PicoMite .
F1 doesn’t save the program to the SD card. It saves it in memory. To actually save the program to the SD card, you have to type SAVE “yourprogname” if B is your default drive or SAVE “B:yourprogname” if B is not your default drive. Of course, you replace yourprogname with your own program name.
