If anyone has their main board out could you please measure the INSIDE distance between these two edge’s in mm ?, as accurately as you can as its going to be tight …
About 3.8 cm, +/- 0,5mm, about 0,00002361 US Mile, to small to convert to furlong ![]()
Thanks !. I have 35mm to fit into that
, getting 17 wires out from there is going to be a challenge tho as can’t see if its safe to remove any of the circuit board…
