GPIO Expansion / Memory Expansion
So, I was curious and was doing some research when I came across a GPIO expander for the Pico using MCP23008 chips. I decided to do some more research on using shift registers and came to the conclusion, yes, I can expand the SRAM & Ram situation on the Pico. Even though it’d be stupid slow I’ve decided I’m going to pick up this project, I just placed an order at Radwell & DigiKey. Everything should be here by next Friday. I’ll make a public repo & I’ll post a bunch of pictures to this thread when I get the chance to build everything. Wish me luck
I went with:
HM62256LP7 32KX8 x1
MCP23008EP GPIO Expander x1
SN74HC595 8-Bit Shift Register x2
So 8mb of PSRAM of already included external memory is not enough for you apps?
No, it is enough. This is more or less doing something just because I can.
This also lays out the path for a module framework for all types of IC’s not just sram.
Today’s the day! My ICs are out for delivery. Even though I’m working 12-hour shifts this weekend, I’ll be setting aside 1-2 hours to lay everything out on a breadboard.
Update # 1
Im going to try and make this readable so bare with me. I broke it into parts for better understanding, i rewrote this like 4 times. I’ve decided until I iron out all of the kinks I wont be posting anything to github, Sorry for that.
So heres what I’ve got so far.
The first test was with the PSRAM,
  • CS_PIN = Chip Select, high means it enables and low is disable.
  • SPI OPEN 1000000, 0, 8, 5, 6, 7 1mhz, Mode 0, transfer size, SCK, MOSI & MISO pins. Since picomite cant use the hardware SPI on the gp pins, it bit-bangs them in the program.
An example of writing a byte to memory: PSRAM write command, W 0 123, the program should come back with Wrote 123 to 000000 (decimal for 0x7B) & stores it in 0x000000
Read example: R 0 would then read the memory location from 0x000000 which would return 0x7B.
Fill example: F 0 255 170. This fills memory from address 0x000000 to 0x0000FF with 170 (0xAA)
Dump example: D 0 64. This shows 64 bytes starting from address 0x000000, the hex dump should be in 16 byte lines (can change within program its Line_WIDTH = 16 dont go higher than 32)
Pointer Dump example: S 512, tells the program to set a pointer at 0x000200 (512 decimal). N32 would dump 32 bytes from the pointer until it advances to 0x220
Checksum example: C 0 256. Calculates the sum of 256 bytes from an memory location. Replace 0 with actual location you want to calculate. When you change a byte the checksum changes, W 0 1 which is writing 1 to 0x000000 which then if you were to run C 0 256, it should come back with 57 (WIP SOMETIMES CRASHES)
Combine examples: Say you want to fill 1kb of memory, F 0 1023 85 fills 0x000000 to 0003FF with 85, then run a checksum C 0 1024 to verify that its filled.
  • For testing higher addresses (WIP) W 1048575 42, write 42 all the way to 0x0FFFFF almost 1mb.
The 4 wire protocol:
  • SCK is the clock on the SRAM. Its stepped currently cant find a stable freq to run at
  • MOSI is Master Out Slave In, takes the data from the pico and stores it on the SRAM
  • MISO is Master In, Slave Out, takes data from the sram and sends it to the pico
  • CS is chip select, tells the SRAM when a command starts & stops
  • A2 = (addr >> 16) AND &HFF is the top 8 bits of a 24 bit address
  • A1=(addr >> 8) AND &HFF is the middle 8 bits of the address
  • A0 = addr AND &HFF is the lowest 8 bits of the address
  • PIN(CS_PIN)=0 pulls cs low to start the transaction
  • SPI WRITE &H02 sends the write command
  • SPI WRITE a2,a1,a0 sends the address
  • SPI WRITE val sends one byte of data.
  • PIN(CS_PIN)=1 pulls CS high to end the transaction.
Heres an example of how the code works if you call: W 0x1111 0x55
CS=LOW
WRITE 0x02 -PSRAM sees the write command
WRITE 0x00 0x11 0x11 - Address is sent, 0x001111
WRITE 0x55 - Sends what data is being written
CS=HIGH - commits the data (ends transaction)
Why did i chose to go with 24 bit addresses? Simple, the PS protocol expects a 24 bit address even if the chip is smaller (learned the hard way). & I’m pretty sure the top 4 bits are ignored if i didnt.
Current command list:
  • W < addr > < val > - Write 1 byte to an address
  • R < addr > - Read 1 byte from an address
  • F < start > < end > < val > - Fill a block with a value
  • D < start > < len > - Dump memory as hex
  • S < addr > - Set the pointer to an address
  • N < len > - Dump from the pointer and advance
  • C < start > < len > - Computes checksum over a block
Update #2
I have create the repo for this project.
Heres a list of what I’ve fixed so far & whats left to do.
Fixed:
  • Powerup delay problems, the board takes about 10 seconds to initilize after the program starts.
  • Keeping CS low during writes & high during reads for longer, about 120ms delay between reading & writing.
  • Pullup resistor for MISO
Added:
  • RANDOM TEST Command, stress tests the psram by writing & reading random to and from the psram.
  • PSRAM auto-detect sizes, This is limited to 16mb until i get a bigger PSRAM chip.
  • Per the CS low fix, I added something called, Burst Wires. It essentially keeps CS LOW and streams multiple bytes to fill large blocks faster, same with write.
  • Added a soft check for clock speeds for the PSRAM. If it fails to run at the given program speed (1Mhz) it will default to 500hz.
