Hi all, i just wonder what the plan about the GPU hardware GLES support for the GS ?
What’s the roadmap about that ?
Thanks
The work by NextThingCo to achieve this on the PocketCHIP with a debian toolchain should come in helpful: https://github.com/NextThingCo/chip-mali
is possible using it as cuda?
for example to tensorflow?
Cuda is nvidia only thing.
And there are other arms for machine learning https://www.theverge.com/2017/5/29/15707606/arm-cortex-a75-a55-mali-g72-specs-announced
If you are interested in ML look at what they’ve done at http://jevois.org, they are using an allwinner chip and use the Mali for GPU acceleration .
But don’t expect tensorflow or caffe to run (well) on a device like the GameShell… it is really not made for (like all ARM devices including the RaspberryPi)
