HackerGadgets AIO Board and Quectel EC20 4G LTE Core successfully activated!
System: ClockworkPi-Bookworm-6.12.34 from Rex
Extension board: HackerGadgets AIO Board and the Package from Rex
4GLTE Core: Quectel EC20/EC25
If anyone is interested in this, please leave a message and I will compile the tutorial
For the next, I will try to work through Quectel 5G RG255C Core
Whats that battery mod?
It’s a 20000mah battery, and I bought the battery board from a Chinese second-hand e-shop. But it’s not necessary for the 4G function, I just want my equipment can last long
Do you have a link for the printed rear cover please?
I’m also interested in that battery board! I have a 4/5g setup I’m working on, but am running out of space. Getting both a larger battery and more room inside would be so nice.
Will that battery fit in the stock metal back, and if so, will you please post a parts list?
Hello, great project!
Is this the original antenna?
Best regards
Pretty sure it’s this one:
That looks like it, thanks. No wonder I couldn’t find it online, I’d never have thought of searching Git for STL files.
I actually discovered it while browsing Reddit, and it printed out very well
Yes, it’s possible, but it can be expanded to a maximum of 10000 milliampere hours of battery. 20000 milliampere hours is too thick and requires reprinting the backplate.
Battery expansion plan:
  1. A battery adapter board, which requires drawing or trying to search on AliExpress, or later I will publish an AliExpress link and contact the merchant to list it on AliExpress
  2. A lithium battery, model 9858102, needs to be equipped with a 5A protection board to avoid overcharging or overdischarging, and a 2pin 2.54mm power cord
Well, you can consider using the original patch antenna or adding a 4G glue stick antenna
hi,’m going to buy a ec20 4g usb dongle,can you share the tutorial
你好,我也打算去闲鱼购买一个usb 接口的 ec20 4g模块,请问这个需要特殊的驱动或者设置操作吗
