I wanted to recompile my version of RetroArch because I use it as the main menu, kind of Lakka for clockworkpi (showing battery info, wifi, power off option…). The advantage is that I don’t need to run Xorg, and I reduced boot time. Retroarch is the only thing that I use.
The problem is that compiling RetroArch in the OS v0.5 with lima I get a black screen, so I decided to compile my lima mesa driver because probably some dev libraries were missing in the v0.5.
I compiled the mesa drivers, and I got my custom retroarch working together with my mesa driver (v 20.0) compiled with:
meson build/ --optimization s --buildtype release --prefix=/usr --libdir=lib/arm-linux-gnueabihf -Dgallium-drivers=lima,panfrost,kmsro,swrast -Dplatforms=x11,drm,surfaceless -Dvulkan-drivers= -Ddri-drivers= -Dllvm=false
like described here: https://linux-sunxi.org/Mali_Open_Source_Driver
Everything works fine except when I try to load a save state . My screen start to flicker and frezzes. I get this message if I run dmesg:
[ 176.939174] lima 1c40000.gpu: gp error irq state=400000 status=b
[ 176.945589] lima 1c40000.gpu: gp task error int_state=0 status=8a
Do you guys know what maybe I’m doing wrong when I compiled the mesa?
for retroarch compilation I used:
CFLAGS=-mfpu=neon ./configure --enable-udev --enable-floathard --enable-neon --disable-oss --disable-vulkan --disable-xmb --disable-ozone --disable-discord --disable-materialui --disable-qt --enable-pulse --disable-jack --disable-wayland --enable-opengles --enable-kms
I’m compiling retroarch v1.8.4, I tried a clean compilation (without my modifications) with the same results.
Thanks in advance
) the yellow text is readable whereas the notification widget is most of the time impossible to read unless you make the fonts very big, and possibly doesn’t fit on the screen.
