I’ve been trouble shooting this issue for a week now and I need some help.
here’s the Meshtasticd.service error log that it keeps through. My meshtastic WAS working a while ago, but hasn’t worked since an update.
dragon@raspberrypi:~ $ journalctl -xeu meshtasticd.service
Dec 03 19:17:33 raspberrypi meshtasticd[3101]: ERROR | 19:17:33 0 Could not open / read /prefs/uiconfig.proto
Dec 03 19:17:33 raspberrypi meshtasticd[3101]: INFO | 19:17:33 0 Wanted region 0, using UNSET
Dec 03 19:17:33 raspberrypi meshtasticd[3101]: INFO | 19:17:33 0 Sort took 0 milliseconds
Dec 03 19:17:33 raspberrypi meshtasticd[3101]: INFO | 19:17:33 0 Running without TFT display!
Dec 03 19:17:33 raspberrypi meshtasticd[3101]: WARN | 19:17:33 0 Packet History - Invalid size -1, using default 400
Dec 03 19:17:33 raspberrypi meshtasticd[3101]: INFO | 00:17:33 0 External Notification Module Disabled
Dec 03 19:17:33 raspberrypi meshtasticd[3101]: INFO | 00:17:33 0 Start meshradio init
Dec 03 19:17:33 raspberrypi meshtasticd[3101]: INFO | 00:17:33 0 Radio freq=906.875, config.lora.frequency_offset=0.000
Dec 03 19:17:33 raspberrypi meshtasticd[3101]: INFO | 00:17:33 0 Set radio: region=UNSET, name=LongFast, config=0, ch=19, powe>
Dec 03 19:17:33 raspberrypi meshtasticd[3101]: INFO | 00:17:33 0 myRegion->freqStart → myRegion->freqEnd: 902.000000 → 928.0>
Dec 03 19:17:33 raspberrypi meshtasticd[3101]: INFO | 00:17:33 0 numChannels: 104 x 250.000kHz
Dec 03 19:17:33 raspberrypi meshtasticd[3101]: INFO | 00:17:33 0 channel_num: 20
Dec 03 19:17:33 raspberrypi meshtasticd[3101]: INFO | 00:17:33 0 frequency: 906.875000
Dec 03 19:17:33 raspberrypi meshtasticd[3101]: INFO | 00:17:33 0 Slot time: 28 msec, preamble time: 131 msec
Dec 03 19:17:33 raspberrypi meshtasticd[3101]: INFO | 00:17:33 0 Final Tx power: 22 dBm
Dec 03 19:17:44 raspberrypi meshtasticd[3101]: INFO | 00:17:43 10 SX126x init result -2
Dec 03 19:17:44 raspberrypi meshtasticd[3101]: WARN | 00:17:43 10 No sx1262 radio
Dec 03 19:17:44 raspberrypi meshtasticd[3101]: free(): invalid pointer
Dec 03 19:17:44 raspberrypi systemd[1]: meshtasticd.service: Main process exited, code=killed, status=6/ABRT
░░ Subject: Unit process exited
