Uconsole and Meshtastic Support
Has anyone got a Meshtastic node working on uconsole? I know the SX1262 chip supports it but am new to Mesh radio and was wondering if there were folks out there that have already made this work?
Yes it works. meshtasticd together with meshtastic-ui or the web ui. the hacker gadget aio package by Rex makes it easy, or you can self install. (i did the self install)
OK I kinda figured it would.. I have Rex’s package installed and am at a stand still as I dont know enough about either lora or meshtastic to know where to start. Is there any kind of a broad or high level how to available anywhere?
Hopefully the above may help
What country are you in?
Colin, Thanks that definitely assisted got it mostly completed however lost display upon checking it just before trying to use the Webserver. I am using Rex;s image with 6.12 Bookworm, with a CM5. I know if I comment out the 2 lines from step 1 in the instructions i get my display working again so there must be a configuration issue regarding the SPI setting and the fact im using a CM5. Understand if this is out of your wheelhouse and just wanted to say Thank You and appreciate the assist.
As a work around install ‘clockworkpi-backlight and then uncomment those lines.
Rex Thank You I shall try that right now…
Rex … Nope that didnt work i get the screen backlight now but still no display.
-Brian-
Make sure you have the following in you config.txt if you’re not using my package to install it.
dtparam=spi=on
dtoverlay=spi1-1cs
dtoverlay=spi0-0cs
That fixed the Display thanks Rex.. im heading to work ill verify all other aspects of Meshtastic are working when i get home. Have a great day and thanks again!
-Brian-
i you the uconsole terminal only and i love using contact GitHub - pdxlocations/contact: A Console UI for Meshtastic it has even a smaller ui setting, so it fits on a beepy too :wink:
just pipx install meshtastic and contact
If someone has issues to get meshtastic-mui working with the ParrotOS release.
just change the source.list entry in:
/etc/apt/sources.list.d/network:Meshtastic:beta.list
deb http://download.opensuse.org/repositories/network:/Meshtastic:/beta/Raspbian_12/ /
to:
deb http://download.opensuse.org/repositories/network:/Meshtastic:/beta/Debian_12/ /
Hi, I have the AOI board and meshtastic-mui running fine on the Trixie image.
Everything works fine but the audio alarm.
Is there any way to get sound via the speakers if a new message arrive ?
Got Meshtastic working on mine finally, but am wondering if there is a way to run LongTurbo on it. It does not show up on the options within the node configuration. In my local area, everyone switched over the LongTurbo about two weeks ago.
