Hello,
I want to write a python script that allows me to jog a motor based off a joypad button press. Where can I find access to the raw input commands for the joypad and game buttons?
It’s at /dev/input/js0, though you may want to use a higher-level library with Joystick support, like Pygame.
Do note that the HID device descriptor reports way more inputs than it actually has
If you do want to go down the route of reading the raw commands, do note they are a binary data format. You’ll need to use the struct module to align with what the Kernel provides. See the Kernel documentation for details.
I think something like pygame is more than perfect for what I need! Thanks!
Edit i am using the keyboard libray now, i assume that wont work for the joypads.
I haven’t tried that library, though I’m not sure that’s a safe assumption. I guess you’ll see as you use it
