I would say I agree. After doing the re-install, then trying configuration again, nothing happens.
could you flash a spare sd card and try on that?
Maundy key word layout issue or you are not used to the uconsole keyboard
Hello. I had the same issue and was able to correct it using these steps and the build from Sept 11th. Forgive the AI copypasta.
First I updated the system locale:
1. Edit /etc/locale.gen:
- Open the
/etc/locale.genfile with a text editor as root:
Code
sudo nano /etc/locale.gen
Uncomment the line corresponding to the desired locale (e.g.,
en_US.UTF-8 UTF-8oren_GB.UTF-8 UTF-8) by removing the#symbol at the beginning of the line. -
Save the file and exit the editor.
2. Generate the locale:
- Run the
locale-gencommand to generate the selected locale:
Code
sudo locale-gen
Alternatively, you can specify the locale directly:
Code
sudo locale-gen en_US.UTF-8 UTF-8
or
Code
sudo locale-gen en_GB.UTF-8 UTF-8
3. Set the system locale:
Edit the /etc/default/locale file.
Code
sudo nano /etc/default/locale
- Ensure the file contains the following lines, replacing
en_US.UTF-8with your chosen locale:
Code
LANG=en_US.UTF-8
LC_ALL=en_US.UTF-8
LANGUAGE=en_US.UTF-8
Save the file and exit.
4. Reboot the system:
- Reboot your Raspberry Pi for the changes to take effect:
Code
sudo reboot
Then I updated the keyboard layout (THIS DID NOT WORK ON THE PREVIOUS PARROT IMAGE)
Open a terminal.
Run the following command with
sudoprivileges to start the configuration utility:sh
sudo dpkg-reconfigure keyboard-configurationUse code with caution.
I had to choose OTHER > US > US Default > And no special key assignments.
A dialog-based interface will appear. Follow the on-screen prompts to select your keyboard model, country of origin, and desired layout.
Once you have made your selections, you may need to reboot your system for the changes to take effect.
