Keypad not working
Hi guys , im coming here after a while and tried everything possible .
Basically : my gameshell is working perfectly , ( os booting , screen working , … )
BUT the keypad is not working , tried to invert the cable , unplug / plug many times , tried to remove the battery , boot it without the keypad ( btw there is 2 led lighting on the keypad board )
Thanks to @Godzil who told me to plug it on my pc , is being detected on my pc .
So if @yong @hal have any solution for me , it would be great .
UPDATE : Tried this tutorial [Tutorial] How to compile and upload code to the keypad , it worked but the keypad still not working
UPDATE 2 : After some help from @Petrakis, we tried with debug 1 , the keypad IS working but seem like its the port from the motherboard !
Best regards , Lenux :wink:
@hal / @yong After some debugging using the modifications to the code I made https://github.com/Mihaylov93/Keypad/blob/master/clockworkpi_keypad.ino
We tested that the keypad board works, the problem one of the following:
  • Cables not fully inserted.
  • Cable connector broken/defective.
  • Board connector broken/defective.
We got your email, I’m sorry for this problem, we could send you a replacement cable, with connectors on both ends?
Is that OK?
what if the connector won’t work :confused:
im really scared about this , but if it does work why not
But how are the board connectors?
Not working at all for the keypad
But are they visually ok? If they are not a new cable wont do nothing
yeah , so that mean i will need a new board ?
@hal @yong
I encountered with the same problem BUT NO led lights on KeyPad board:
  1. tried another 4 pin cable , still NOT working.
IMG_3765
I asked for a new mainboard i should get mine soon
@yong
I send email to help@clockworkpi.com 3 days ago ,and no reply yet.
Just received the main board … Im quite deceived , after some try on the same problem repeat @yong i dont know where the problem is coming from … it worked for 4 touches then nothing .
Thanks for this product , was funny if it would have worked .
Anyways i might come back when the product WILL be ready and perfect .
EDIT : !!!After some retry it work i will get back soon if its not working everytime .
That is weird, I mean one not working I can understand, replacement not working too, you may have a bigger problem.
What did they send you as a replacement? the keypad or the mainboard?
Have they sent you a set of wires too?
After edit up it worked i just had to turn off / on again my gameshell @Godzil
:smiley:
It is working! :slight_smile: :champagne:
I 've got the new mainboard from clockpi t4eam
and some awesome new feature~~,
and works now~
Thanks yong! @yong
I’m interested to know what this awesome new feature is :thinking:
