Luckfox Lyra on PicoCalc
So I think I need to catch up / sum up on this thread…
I picked up a Luckfox Lyra B 256.
I erased the flash.
I think I now need to:
  • setup an SD card with one of the images @hisptoot posted on Google Drive (although I’m using Linux so I’m not 100% clear how to do that to make it bootable, I’ll dig in on that)
  • decide on a wifi option (soldering something in, or using the USB / MX 1.25 adapter)
  • optionally solder a wire between pins and remove a couple of them from the board to enable the hardware pwm audio. There are some images in this thread but a more specific set of instructions would be wonderful.
  • optionally solder in / connect an RTC, again going from images etc above.
  • optionally print a nicer back case
Is that about right?
