I’m following this guide:
To build a CM4 OS image from scratch.
Most of it works fine, but when reaching the desktop, lxpanel crashes.
If you do “Ctrl-Alt-T” to get a terminal and then manually run “lxpanel -p LXDE-pi”, you can see it crashing:
** Message: 00:14:17.372: x-terminal-emulator has very limited support, consider choosing another terminal
grep: /home/lion/.config/lxpanel/LXDE-pi/panels/*: No such file or directory
** Message: 00:14:17.756: netman: network manager service not running; plugin hidden
** Message: 00:14:17.786: Connecting ...
** Message: 00:14:17.787: Status changed to down
** Message: 00:14:17.787: Status changed to opened
** Message: 00:14:17.787: Connected to dhcpcd-8.1.2
** Message: 00:14:17.788: Status changed to connected
** Message: 00:14:17.789: eth0: Link is down
** Message: 00:14:17.789: wlan0: Not associated
** Message: 00:14:17.789: eth1: CARRIER
** Message: 00:14:17.789: eth1: Configured 172.16.221.230/16
** Message: 00:14:17.789: eth1: ROUTERADVERT
** Message: 00:14:17.790: eth1: Configured 2601:647:4c01:4690:0:d:0:76bd/128
** Message: 00:14:17.791: wlan0: WPA status connected
** (lxpanel:4907): WARNING **: 00:14:17.852: init context: err:6 Connection refused
** (lxpanel:4907): WARNING **: 00:14:17.855: init context: err:6 Connection refused
** Message: 00:14:17.962: ptbatt: battery entry BAT0 not found, using axp20x-battery
Segmentation fault
This isn’t the “no battery” bug. I have batteries installed and in fact no external power.
Any ideas?
