LyraCalc OS – Ubuntu-based OS for the PicoCalc with Luckfox Lyra
Hi everyone!
For the past few months I’ve been working on my own OS for the Luckfox Lyra in the PicoCalc, and it’s now available on GitHub.
LyraCalc OS is based on Ubuntu 24.04 LTS, so you get the full power of apt and can install pretty much anything right on the device.
Highlights:
  • micro editor with rich syntax highlighting and error checking for the most common languages (Bash, Lua, Python, C/C++)
  • Everything set up to flash and program ESP32 boards with MicroPython
  • PICO-8 runs smoothly, with full SPLORE support (bring your own copy), plus TIC-80
  • Many USB WiFi sticks supported out of the box
  • A small status overlay showing CPU and RAM load, FPS, WiFi and battery
Good to know:
  • Sound needs a small hardware mod on the Lyra (one 0 Ω resistor removed, one wire bridge).
  • Optionally, an updated STM32 keyboard firmware fixes the right Shift key and adds the Alt+O shortcut for the overlay.
GitHub: GitHub - LucaWoro/lyracalc-os: Linux distribution for the ClockworkPi PicoCalc with Luckfox Lyra · GitHub
Short video: https://www.youtube.com/shorts/iT6mZX0y_RY
Feedback is very welcome, and if you run into problems or bugs, I’d be glad to hear about them!
About Calculinux: I know Calculinux and it’s a great project! LyraCalc OS just starts from a different base, so it’s not one vs. the other. They serve different use cases, and with two SD cards you can happily use both. If my approach isn’t for you, be sure to check out the Calculinux megathread here on the forum!
Thanks!
