I was trying to adjust my terminal settings for my old weak eyes. Just want to make to font bigger. I used lxterminal preferences and picked a font in Style, then went to Display and changed Default Window size. And now everything in the terminal window is wonky. Like the cells for each character are too wide, so there’s too much horizontal space between characters.
Like an idiot I failed to note down what the original settings were…
Can anyone help point me to what the default window size should be for my uConsole? Or teach me how to maybe reinstall lxwindow?
Thanks Alex, deleting the file cleared it up back to normal.
Can you offer advice on what parameter(s) to change or what method to use to increase the font size without throwing the character spacing off?
Hello again Rex - do you know of a way to set the screen defaults so that new windows will open with the new larger settings? Like using Ctl - Sft -+ to get the size I want then making those settings be the new default that new windows open as?
Also, back in the day I had a multiple virtual desktop setup on my Linux system, but under Trixie (I’m pretty sure that’s the release I’m running) I can’t find any of the methods documented online that work.
the first one i’m not sure i haven’t tried to set it permanent, i only need to change it sometimes to read it.
multiple workspaces though i can help with, here’s my copy of rc.xml for labwc located in ~/.config/labwc/rc.xml then logout and back in the key bindings i have set are ctrl+left/right
it’s the stock rc.xml just with workspace switching added.
You can change the key bindings to something easier if you want. I just use that because the only time I use multiple workspaces is when using a keyboard and monitor.
