Any idea why my terminal looks like this after the last update and how tf I can get it back to normal?
Looks like it’s attempting to use a variable-width font; probably the one you were using was renamed or replaced in the upgrade. Tried setting a new font?
Would that be done in the config.txt?
try ctrl - to see if the font size will shrink…
As someone said, it looks like it is using a variable-width font as if it were a fixed-width font. Easiest solution is probably just to select a different font. This post from the Devterm forum looks relevant:
