My 18650 batteries vented when I put them in the PicoCalc
They were unprotected batteries, and when I put them in my PicoCalc recently, I may have put them with reverse polarity, which caused them to vent. I instantly removed the batteries from the PicoCalc, and I don’t think any damage has happened to my PicoCalc’s battery holder.
I need to buy new PROTECTED 18650 batteries.
If your reading this, and you have a PicoCalc, could you do me a favor.
  1. While you have your batteries in, turn on your PicoCalc, and put your ear to the raspberry pi pico, do you hear a buzzing sound?
  2. Now do the same thing, but without batteries, but power your PicoCalc through usb-c and tell me if you can hear a buzzing sound.
Normally there won’t be a buzzing sound
we don’t know what kind of buzzing sound you have
So is it possible to record a video about this buzzing sound?
I cant send video here
ok
do you have youtube?
yes, oh, I see what you mean. unlisted
found something more concerning…
my raspberry pi pico 2W smells like its burning on use.
Not PicoCalc’s fault, but my fault for shorting it.
but it does turn the PicoCalc on and stuff…
I’ve checked my picocalc with Pico . running PicoMite
I unboxed the shell, put my ear very close to the Pico , No sound at all
re-checking your machine’s assembly of course
if you feel like this is a hardware problem, maybe send email to help@clockworkpi.com
18650s aren’t simply “better AAs”. You need to treat them with respect, and don’t just assume that everything will be ok if you do something dumb. Any time you have a loose cell you have to think through everything you’re doing before you do it, then stop and check again.
And “protected” cells aren’t magically safe either - they can potentially prevent certain classes of failure, but they’re not idiot proof, and they can make you complacent.
If my battery vented and shorted out, and also shorted out my pico 2W, do you think that the battery holder and charger works.
The display, audio, sd card slot and keyboard still work.
but recommended (my opinion).
AXP2101 Single Cell NVDC PMU with E-gauge
According to the data sheet: AXP2101 is a highly integrated power management IC (PMIC) targeting at single cell Li-battery applications …
The picocalc is a single cell device - or more accurately, it’s a 1s device. If you put two cells in, they’re connected in parallel and are electrically identical to a single cell with twice the capacity. The AXP2101 is being used appropriately.
That actually brings up another issue with using 18650’s here - if you put two cells in, they must be charged to the same level (within 0.1v!). Otherwise the higher voltage cell will pump current into the lower voltage cell uncontrollably. This is bad. The simplest way to deal with that is just to fully charge each cell independently with the same charger before installing them. Once they’re installed and at the same level, they’ll remain matched.
Wait, when you checked this, did you have batteries in, or connected to mains via usb-c?
Also, as my batteries short circuited, and so did my Pico 2W, the sd card slot, keyboard stuff, display, and some key circuits are guaranteed not to be short circuited, but about the battery holder, and the pin slots to hold the Pico, I don’t know about them. Because, this buzzing, may be caused by the short circuiting, or the high amount of power, been given through mains, as appose to the power you would get with batteries.
I’ve checked with one battery and via usb-c , both have no buzzing sound
oh… that might mean my board is broken.
Is there anyway to stop this buzzing and fix any issues on the motherboard, without buying a new one?
From other early posts, I believe you swapped out the original Pico, with a Pico2, so I’d try swapping it back in to see if it still makes the noise. If the noise goes away, it means the problem is with the Pico2 and not the PicoCalc itself. If that’s the case, I’d wipe the Pico2 and reflash it to see if that makes sny difference.
Off hand, if the PicoCalc is otherwise working, the only other things I can think of that could possible make a buzzing sound is the audio circuitry or the backlight… We ran into noise from backlights occasionally in my old company.
yeah I swapped it, and same buzzing sound is present.
and it’s coming from the area around the pico, probably somewhere near the breadboard holes.
