New Hacker Gadgets Dual 21700 Battery Holder
Look this line:
Your: energy-rate: 3.22292 W
My : energy-rate: 5.984 W
The current seems quite low. What is the brand and model of the battery? The batteries could be faulty or counterfeit—it’s rare, but it happens all the time. :slightly_smiling_face:
yup, so it is indicating a hardware fault?
In the best-case scenario, if the board isn’t the problem, it could be a faulty battery. The current is VERY low.
I have swapped out 6x different 21700mah batteries to try and they are all the same results
My suggestion… install the batteries, check the readings with upower, and look at that line. If you don’t see any change, save the output and send it to HG. If everything looks EXACTLY the same, the problem isn’t the batteries—but you need to check the readings. Use upower; it’s a great tool for this.
I always say this… high-capacity batteries alone won’t help. To maintain 5 V, you need batteries rated for at least 30a with a high discharge rate to keep the system stable.
Note: Charge the battery for at least three hours, checking the readings regularly with upower. Your case is really strange.
Note 2: Try a simple test. You have six batteries there, so forget about capacity for now. Use the battery with the highest CURRENT RATING, then try the one with the lowest CURRENT RATING. I’m telling you with 100% certainty: the one with the higher current rating will perform better than the one with the lower rating.
well when I run the uconsole under load such as sdr and some script to generate a moderate load, the batteries will only last 1.5hrs.
playing 1080p videos alone will only last 3-4hrs.
it is definitely weird and something do not seems right
upower -d
Device: /org/freedesktop/UPower/devices/line_power_axp22x_ac
native-path: axp22x-ac
power supply: yes
updated: Tue 06 Oct 2026 06:39:11 PM JST (4099 seconds ago)
has history: no
has statistics: no
line-power
warning-level: none
online: no
icon-name: ‘ac-adapter-symbolic’
Device: /org/freedesktop/UPower/devices/battery_axp20x_battery
native-path: axp20x-battery
power supply: yes
updated: Tue 06 Oct 2026 07:47:26 PM JST (4 seconds ago)
has history: yes
has statistics: yes
battery
present: yes
rechargeable: yes
state: discharging
warning-level: low
energy: 5.04 Wh
energy-empty: 0 Wh
energy-full: 36 Wh
energy-full-design: 36 Wh
energy-rate: 7.12738 W
voltage: 3.471 V
charge-cycles: N/A
time to empty: 42.4 minutes
percentage: 14%
capacity: 100%
technology: lithium-ion
icon-name: ‘battery-caution-symbolic’
History (charge):
1791283646 14.000 discharging
History (rate):
1791283646 7.127 discharging
1791283616 7.294 discharging
1791283586 7.055 discharging
1791283556 7.172 discharging
Device: /org/freedesktop/UPower/devices/DisplayDevice
power supply: yes
has history: no
has statistics: no
battery
present: yes
state: discharging
warning-level: low
energy: 5.04 Wh
energy-full: 36 Wh
charge-cycles: N/A
percentage: 14%
Daemon:
daemon-version: 1.90.9
on-battery: yes
lid-is-closed: no
lid-is-present: no
critical-action: PowerOff
welp, your 1080p playtime seems the same as of a topic starter:
did you measure time of 18650 on stock hardware and of 21700 on HG + nvme ?
Just received my board and batteries, installed them but I don’t have enough time to test tonight. Hopefully the issue you’re facing is a once off :sweat_smile:
That strangely sounds like it’s only running on one of your 21700s, I would be suspecting either the pins between the main board and the power board to not be making good contact - historically with the stock board there have been some issues if you don’t insert it at 45 degrees to get a good seating. That could be one factor in this case?
The other one are the two connectors on the cage, but you’ve done quite a few removals and reinserts at this point so I assume it wouldn’t be that one.
Hopefully, HG is able to provide some support in this case, it’s definitely very perplexing.
hope you can take some observations on how long the batteries charge and discharge on yours.
I have tried both with loads such as sdr radio and without load just idling and the batteries dont last beyond 3-4 hrs
just an update, I have swapped clockwork original 18650 board.
just powered on and idling, uconsole took almost 6 hours to discharge the batteries empty
with light loads, it took about 4.5-5 hours to went from 100%-0%
all the tests were without the rails turned on and brightness at step 2 - 22%
I have utilized Claude to provide scripts to log the power charge and discharge.
the numbers definitely is off on hg 21700 battery board I received unfortunately.
have to wait for hg to be back from holidays to get their support
@vileer does the board implement any sort of temperature monitoring? I’m hesitant to use some of these high capacity bare cells that state they require cutoff. Maybe I’m being too cautious! From what I can tell protected cells would not fit in this unit.
protected cells as in the battery with button as the positive side?
if yes then I am using it with no problem on the battery, the problem I am facing now is the board seemingly problematic on arrival
protected could be either flat top or button top.
can you test 21700 without an nvme?
I did without nvme as well and the result is the same, the batteries just goes flat within 1.5-3 hrs powered on and idling.
in fact I have used Claude to calculate the power consumptions of nvme, wifi and bt etc but they are not the cause.
the 18650 has been running since 2300hrs - 0600hrs powered on and idling and still with 50% battery.
@deathg0d
It does sound like a board defect or something .
I was wondering, can you provide a few close-up pictures of the board and pins?
Maybe one of us might spot something… if you can.
and a picture of battery
here you go. the batteries are brand new so I have rule that out because they charge and discharge normally on an external charger.
I’m suspecting that I might have the same issue. I’m still charging to full and haven’t done the battery calibration yet, outside setting up the capacity device tree overlays. I’m currently at “40%”, upower reads 15Wh current “energy” and voltage is up at 4.07v. At that voltage I’d expect to be reading around 80% and a much higher Wh given the batteries right?
Edit: No, might be a calibration issue, will report back
I’m wondering, do you have a Dedicated Charger?
What I did before I installed mine, I charged it to full on a dedicated charger.
I did the same—I charged them for four hours.
If you’re using two P50B cells with a total nominal capacity of 36 Wh, 15 ÷ 36 ≈ 41.7%. So the 15 Wh reading is consistent with approximately “40%.”
SofterHearts and deathg0d
Try this script I wrote. It logs a bunch of information that may help you diagnose the issue. If you want to monitor the drive too, you’ll need to install smartmontools. Hope it helps!
Script
