In the search for the perfect hard case I came across this Luxtude:
Purchase two of them since I have another PicoCalc on its way.
It fits perfectly with the slide on protector that I had 3-D printed by a friend from files found on this site. Had to do a little bit of filing to have the PicoCalc slide in and out easily enough.
You might need some foam if you just have to PicoCalc buy itself, but with the cover, it is a perfect fit. I have an SD card reader for the laptop, which I keep in this case. Also a micro USB in a USBC cables for the laptop.
Looks like my search is over for the perfect case as it will also contain the 40 page manual referring to the over 80 K worth of programming for aviation that I’ve been working on for the last few weeks
