Picocalc engineering for dillettantes?
Hello,
I am a coding/hardware hacking hobbyist going back to the family 8088 as a kid; never done more than basic IT work for money, sometimes i fix electronics for walkin around money or upsell- but much of my work has been more in the soft skills arena, so i haven’t honed my engineering skills as much as most of u here
I was a little too young to understand the way hardware and software interacted on the very earliest PCs, and newer computers seemed too complicated for me to work with directly, making me work through the abstractions of windows or gnu libraries
The picocalc appealed to me as an approachable device i can more easily make a mental map of than a typical modern PC- but I am having some trouble with learning materials being written either above my head, or, covering what I already know
The Art of Electronics is a book that I adore for its combination of approachability and deep complexity. I’m seeking materials similar to that, to help me understand the hardware. Example tasks I don’t know how to do, but would like to, are
  • Port Pico (generic) software to be compatible with the PicoCalc platform
  • understand how the memory architecture works enough to make intelligent use of PSRAM
  • connect hardware via gpio pins (or USB?) and write code to communicate with that hardware
im working on a little CLI for rolling TTRPG dice that i have expansion plans for- that’s pretty straightforward. but I would also like to see if I could get this thing to e.g. tune AM radio from an SDR dongle (if it has the hertz)
I feel like I can’t be the only one interested in this platform who isn’t completely up on the engineering side of things, but is curious and willing to learn-
What texts from your past have most helped you understand the PicoCalc platform, or, the Pico platform in general?
Having spent the last 3 months building PicoDOS an MS-DOS like environment for the PicoCalc, I have some insight to your questions.
A good place to start is the picocalc-text-starter by @BlairLeduc, it provides libraries for the screen, keyboard and SDcard. I have used it for half a dozen projects and it makes everything easier. No reason to reinvent the wheel.
The PSRAM on the PicoCalc is poorly implemented and is kind of useless. In PicoDOS I was never able to use it for anything other than a RAM drive. I am sure more clever people than me could figure out how to use it actual RAM, but I think most of us ignore it for the most part.
This is actually not much harder than it is on a bare bones Pico. The Raspberry Pi Pico documentation and SDK is the place to start with this.
I’m not sure the PicoCalc is a good hardware tinkering platform, however there are areas where you can use it - the issue (from my point of view as a hardware/gpio tinkerer for a very long time) is lack of GPIO pins - although 6 pins is better than no pins.
The pins that are bought out are mostly the ones that go to the internal PSRAM, so as long as you don’t use that then you can use those few pins. The analog input pin is separate though.
Other ways - I²C - those external pins can be used in I²C mode or (like others) you can solder on a connector to the Picos pins directly. The Pico2+W I’m using has a QWIIC connector but you might need to cut a hole in the case to use it.
(And on that note, a Pico2 with on-board PSRAM is the sensible way to use PSRAM without the need to bit-bang hardware or use the PIO to drive he on-board one - the Pico2 does it at the hardware level and makes the PSRAM look like real RAM to the CPU, complete with a cache).
But for a little CLI type platform it’s good - there are several little stand-alone systems there - even the MMBasic that’s the default could be considered a CLI system - I wrote my own in a suitably retro language (BCPL) - the downside is that to get to a TTRPG dice thrower (which might be e.g. 10 lines of code) you need 5,000 lines of supporting code!)
I got mine as a platform for my little CLI based OS - I already have it on other platforms - some with much more GPIO (which is really my thing, but OS tinkering is also fun).
-Gordon
