Question about uConsole
Hi everyone, I’ll be purchasing a uConsole soon and I have a few questions.
I’m planning to buy the uConsole Kit RPI-CM4 Lite (CM4104000), and I have a few questions:
  1. Can I replace the CM4 with a CM5? I’ve heard it’s possible, but that requires proper cooling.
  2. How can I ensure adequate cooling for the CM5?
  3. Should I buy the CM5 version with 16 GB of RAM and 64 GB of eMMC (CM5116064)? Or will it overheat?
  4. Can I use eMMC + SD card + NVMe? I’ve heard that eMMC and SD aren’t compatible because they use the same bus.
    I want to build the most powerful setup possible without it overheating and while ensuring it runs smoothly. Please share your advice—especially from those who’ve maxed out their builds. I’d appreciate any tips.
you are aware of delivery time, aren’t you? Highest order number that received the shipment notice - #1298 by guru
yes, it even may has sense to not buy cm4 at all
if you are not gonna heavily use it (sdr, compilation) everything will be okay
you can’t have emmc + sdcard, only one of them will work due to hardware limitations.
you can’t have nvme without additional not official boards like one from hacker gadgets
If I buy the version with eMMC, can I switch to SD later, or is it better to buy the one with SD right away?
no, you need to choose
up to you, doesn’t matter if you are going to use nvme.
for emmc version you need to buy extra io board to flash it (or HG adapter board)
for sdcard version you will have to update eeprom and it may be annoying
