I finally got done with this (took about 10 hours or so of planning and getting my fingers hurt lol)
Now I can connect a Pico or Zero without removing the back panel ![]()
close enough welcome back handspring visor springboard modules
I considered various options for the 5V Booster and I2C Repeater for my new relay board.
In the end, I decided it would be best to give the user the option of whether or not to use them
In other words, I designed it so that it would be possible to create boards with the following specifications:
If the 5V Booster is not included, one additional wire will be required.(the red wire shown in the photo).
If the I2C Repeater is not included, one pattern cut (cutting the 3.3V line) and two additional wires (SDA, SCL) will be required. These are relatively simple changes, so there shouldn’t be any problems.
I’ll test this board for a while to see if it works properly.
Great design!
What about the other connection that are omitted by now?
Maybe we should think about how to connect them and write software/configuration for it.
What do you think?
I managed to make the desktop appear smaller. I’m not sure if I did it the right way, but I went into Preferences → Display and then clicked For Smaller Screens
Is there a better way? All the windows (except for some games I tried) do fit within the screen now (even after rebooting)
Thank you.
Yes, it would be great if the SD slot on the PicoCalc itself and some of the GPIO on the RasPiZero2W could be used.
—About SD card slot
The PicoCalc’s SD card slot is controlled via SPI and powered by the AXP2101, so I think it should work if I connect it to the RasPiZero2W’s SPI.
I’m concerned about SD_DET. According to the circuit diagram, SD_DET is pulled up to 3V3_OUT with a 10K ohm resistor.
The wiring shown in “Raspberry Pi Zero 2 on PicoCalc” doesn’t include a connection from the RaspiZero2W’s 3.3V to 3V3_OUT, so SD_DET’s ability to determine the presence of the SD card may be impossible or unreliable.
If SD_DET can be ignored, that won’t be a problem.
If the wiring is done using a different SPI system from the LCD, it may look like this:
RasPICO GPIO — RasPiZero2W GPIO
SPI0_CS GP17 — GP18
SPI0_SCK GP18 — GP21
SPI0_TX GP19 — GP20
SPI0_RX GP20 — GP19
SD_DET GP22 — ?
I think there are some complicated steps to make the SD card usable by Raspbian.
It might be easier to attach an SD card reader to the USB port on the RaspPiZero2W.
— About GPIO
I think it’s a great idea and practical to expose all or some of the RasPiZero2W’s GPIO so that it can be used.
Since it would be impossible to expose all GPIO, I2C and UART, which are likely to be used frequently, would probably be good candidates.
With I2C, if a GROVE terminal can be added to the edge of the board, various experiments will become possible.
I tried this with GP4 and GP5, avoiding GP2 and GP3, which are for the I2C keyboard.
I connected an SHT35 sensor via I2C and was able to measure temperature and humidity.
It might be possible to do the same for UART(GPIO14/15?) by adding a connector of some kind.
There are probably other GPIOs that are suitable, but there may not be any spare space on the board.
P.S.
Oh, I misunderstood.
Does that mean that some of those GPIOs just need to be wired to the GPIO socket on the side of the PicoCalc?
I wired the GPIO socket on the side of PicoCalc as shown below.
I see, this is convenient.
Hi,
Thanks for Insights and toughts.
I think sd card will be possible because it was made possible with the lyra fox. I will check if i find the configuration in @hisptoot github repsitory.
“I wired the GPIO socket on the side of PicoCalc as shown below.”
That is what I meant.
Another thought is:
My case design allows access to the PI Zero GPIO pin on the back.
So I can maybe design some kind of backpack Extensions.
I will try something this week with kicad.
That’s a great idea!
I look forward to your SD developments and new case designs.
Letter arrived today.
THANK YOU!
22 days lol. BTW. I have still boards to give away. (Still not to US because of the tax situation)
7 Boards are still available.
I just tested the 64-bit version and it worked!
However I had to remove this line from setup_keyboard.sh
Interesting. Have you done the stuff with the apt Parameters? Maybe it is installed with another Package. How does it runs with 64 bit?
It’s running alright so far. No issues yet!
I did do the apt parameters:
APT::Install-Suggests "false";
APT::Install-Recommends "false";
but I also installed some stuff I use for development before installing the display/keyboard drivers
Ah, Maybe you installed the Headers accidently. I think they maybe also be called something with 64.
I have not tried 64 bit by now.
But it is great that it works.
Are you going to make a video to help me do it too ?
Or it’s just the same as Michael github just choosing a different os and this line in the script ?
Thanks
EDIT:
I tried it myself and I validate the error for this line in setup_keyboard.sh
The error message is : Error: Unable to locate package kernel-package
Beside that it runs like a charm ![]()
Hi Michael,
I would be highly interested in a board or two, in case there are still some to give away. It does not have a high priority, since I am waiting for my PicoCalc. But I would like to have things in place when it arrives. Many thanks for the efforts you and the others put into this nice project and regards from DE!
Awesome glad you figured it out!! It’s the same steps but without that kernel line
To my knowledge, the 64-bit versions already have a 64-bit kernel installed
@michael_mayer Great job on the trixie port! I am a bit confused about your github instructions on the battery add on and how to set that up.
I also notice that pico-8 is still giving me the framerate error. I made sure my clockspeed was at 50 and still get it. Fiddled around with 60 on the clockspeed but no results.
About pico:
Have you set also the SPI speed?
dtoverlay=mipi-dbi-spi,spi0-0,speed=70000000
You need the clock and the speed parameter.
The battery indicator only works with tmux.
