So now I have noticed rebooting on trixie with CM5 will cause the device needing a battery pull. Can someone else confirm this or is it just my device. Is there anyway to fix this if others have this issue too please confirm if anyone else is having this same issue thanks.
yes, they’ve changed pins on cm4 vs cm5
seems like this fix fixes it, but on your own risk:
Lol wish it was that easy lol thanks for the information at least I know it’s just not me.
HK battery board also allows to solder a switch so you can power it off without opening the case
我也是cm5 运行trixie,没遇到你说的重启需要拔掉电池的情况。
除非死机或者低电量造成的不能通过顶部开关来关机,这时候才需要拔电池。
Try a reboot don’t shutdown but just reboot the system will crash.
It should reboot fine with the new battery board. That cutoff switch is only if the kernel crashes. You must have some other software installed or something that’s causing reboot issues. Or maybe your nvme or something. It should reboot fine though
Okay I will need to check what’s up once I get my battery board back it’s gone off for power switch mod as above. I did install the sleep screen app may be this is doing something it was this one uConsole-Sleep v1.3
