as soon as i take out the sd card i cannot get it working again.
nvme + sd card will not boot from nvme again… only if i burn on sd card and fresh burn on nvme and do the same process again… only one boot on nvme is possible
*** CREATED UPDATE /tmp/tmpg4rkotsy/pieeprom.upd ***
CURRENT: Mon May 11 11:20:02 AM UTC 2026 (1778498402)
UPDATE: Mon May 11 11:20:02 AM UTC 2026 (1778498402)
BOOTFS: /boot/firmware
‘/tmp/tmp.wbCKp65UKu’ → ‘/boot/firmware/pieeprom.upd’
UPDATING bootloader. This could take up to a minute. Please wait
*** Do not disconnect the power until the update is complete ***
If a problem occurs then the Raspberry Pi Imager may be used to create
a bootloader rescue SD card image which restores the default bootloader image.
I would do other way.
First, boot system from SDcard (without NVME), set it up and have a proper booting device.
Then, connect NVMe, use SD Card Copier (https://forums.raspberrypi.com/viewtopic.php?t=234411) and copy from SD to NVMe. Shutdown, remove sdcard and boot.
For config, try:
dtparam=pciex1
dtparam=pciex1_gen=2
I had some issues with stability on gen3 - long wire paths were not great for such speeds.
Above approach worked for me (and still works). With bootable SD cards allows me to boot Kali (SD) and Trixie (NVMe).
shutdown and reboot works from nvme (with out sd card) . finally, my 3 days of trying, mounting, dismounting and flashing sd cards and m.2 drives ended.
right now i am on:
dtparam=pciex1
dtparam=pciex1_gen=3
but reboot and shotdown needs a little longer as with sd card
That’s correct - I think it flushes and syncs some kind of cache on NVMe - I’ve tried to debug it on gen3 and found out, that on gen2 it’s faster in my case.
Still have no idea what’s keep it powered on - however, system speed, boot, loading times, and size is more welcome than speed of shutdown/reboot. I can live with it
Maybe wrong but you were trying to boot from NVME with no OS on there !?..
Yes I did the same, booted from Trixie on a fast micro sd card while blank NVME installed, changed boot options, used the sd card copier built into Trixie, switch off and remove the micro sd, reboot, voila.
I then reformatted the sd card to exfat (difficult as Linux format notoriously difficult to fully remove) and use it to hold my documents, movies, music etc (hence boots faster from NVME too as doesnt get stuck trying to boot from a ‘missing’ sd card). Now and then I also use sd card copier to backup my 256Gb nvme to a 256Gb micro sd card inserted into an adaptor in the AIOv2 usb-c socket, doesn’t take long with a fast card…
Running for quite some time - no issues there.
But you say that it was working before - you assembled it back and doesn’t boot?
Maybe ribbons are not connected as they should - or battery are insufficient?
Could you post some photos, please?
I’m running at Gen2 with cheap Kioxia KEG60ZNS512G (512GB).
Regarding running Gen3 than Gen2 - no significant impact on that.
As per documentation of CM5:
One-lane PCIe Gen 2 (5 Gb/s) host interface for high-speed peripherals.
EDIT:
Actually, I had issues with it - once when I’ve did not connect it fully with ribbon, once when I was trying CM4-Adapter (Waveshare “raiser” card) and once when dealing with GPS always on on AIOv2 - I’ve did not inserted adapter board fully. Photo of open uconsole would be helpful to investigate it thoroughly.
Seems fine - just the ribbon on the HG HUB seems little crocked for this point of view.
You are running with flatpack battery? Any luck on that?
I’ve been trying with 10Ah flatpack - but the voltage sag was so excessive that I’ve gave up on that idea for now.
Next step is to try powering it with dual 10Ah in 2S configuration with step-down DC-DC
Glad to hear that it works now. I’m not sure if path to NVMe isn’t too long for it to operate at such speeds. Like I’ve previously said, I had mixed results with Gen3.
Yeah, dropped quite a lot, but that’s not end of my story yet. I have an idea to do 2S cell, or more.
You can solder 18650 - I’ve got on mine original one, but I have removed and restored it like 6 times already. I’ve got myself 4Ah Nitecore batteries and they quite good. 3h of runtime with sdr.
