Rogue: Exploring the Dungeons of Doom
I’m having too much fun with this!
Can I request a default options file? Maybe just a little text doc that goes in the Rogue folder?
I would try to add that in myself but I haven’t had access to a “big” computer for the past week
I am too! I am not a great player, but I am getting better!
Yes, already implemented, look in GUIDE.md under options.
Thanks for the detailed explanation.
Currently, stable operation is expected on Pico2, so it’s a good idea to play with that.
My PicoCalc has a replaced backplate so that the microcontroller board can be easily replaced, so I’m enjoying Rogue on Pico2.
However, it’s difficult to reach the abyss.
I would be in 2nd place on your leaderboard! :slight_smile:
I just gave this a try :fire:
I clearly suck at the game lol but looks interesting. I’ll definitely play around it some more this evening.
To my understanding it’s turn-based and text only? I was thinking about porting this into Picoware
it’s one of the first games so there are not much graphics.
have you heard about game genre named ‘rogue like’? They are games like rogue…
Ah that makes sense. It’s a bit before my time but upon further research I see it’s RPG and random generated worlds! That’s actually really cool
it’s usually a dungeon and you go deeper and deeper and after death you start from the beginning, but you know a bit more so you go further next time.
first diablo meant to be a roguelike: turn based dungeon, but they changed it during development.
Rogue 5.4 was released 40 years ago this year. I chose the last version of the original Rogue to bring to the PicoCalc.
I should add that you are playing Rogue 5.4 compiled from the original source, except for:
  • Rogue required a 80 column by 24 line screen, I changed this to 64 columns by 32 lines to fit the PicoCalc screen.
  • I needed to change some text to fit in 64 columns.
  • The random function to use the hardware random number generator on the Pico.
  • Since we don’t have a home directory, I set that to “/Rogue”.
  • I created a “shell” around Rogue to give it a place to live on the PicoCalc.
My changes are “patches” to the origin source to make sure the original source is used and allow you to inspect what I changed.
I have added automatic power down of the PicoCalc if you have upgraded to BIOS 1.4.
Thank you for the v1.0 update.
I upgraded my PicoCalc keyboard firmware to v1.4 and then tried playing PicoCalc-Rogue v1.0.
  • Unlike v0.4, I can now enjoy playing Pico (picocalc-rogue-v1.0-pico.uf2) smoothly.
  • Of course, Pico2 (picocalc-rogue-v1.0-pico2.uf2) is also fun to play.
  • The random message and power-off functions after quitting or saving are very useful.
This is a great update. Thank you.
Thank you so much for this…
I spent Sooooo much time in university playing rogue on the old AT&T Unix on a PDP-11/70 and then years later, the reason that I switched from Microsoft’s OS to Linux was because there was a rogue available on early Linux. Later, I migrated over to nethack, but I always have fond memories for rogue and now that I have a PicoCalc, I’m going to “waste” more time. (but it’s OK because I’m retired now).
Thanks again. I’ll definitely report any bugs that I find.
Thomas Dzubin
noobish question, but which files need to go where for this to work? I’m new to the picocalc and haven’t figured that out.
You need to create a /Rogue directory on your SD card.
Im new enough to this that I don’t actually know what that means, sorry.
You need to create a Rogue folder on the SD card. Where are you stuck?
I’m honestly not sure. I have the uf2 file in the uf2 folder, and the picocalc-rogue-1.0 folder in with the rest of the programs, and I’m stuck from there.
I’ve been trying to figure this out on my own, but all I can find are guessy, inconsistent AI answers.
@jblanked Do you have a video that could help @VecTron5 get started on the PicoCalc?
Yes I do! Thanks for the tag.
@VecTron5 This should help with the uf2loader:
And this should help with getting started
Here’s a playlist of tutorials that should help too: https://www.youtube.com/playlist?list=PLSRet1BCVgXhDNONa1T-1OIDoSibsF_ey
