Some Newbie Questions
HI!
I Just received my PicoCalc yesterday and I’ve started to play with it and I had couple questions.
From the files on the PicoCalc Github, am I correct in assuming that the Pico 2 is currently supported? If so, any recommendation on header pins?
I have the PicoMite documentation from Geoff’s site, but beyond the assembly guide, are there any docs specific to the PicoCalc?
I have a couple candidates, but does anyone have any recommendations for cases?
Take a close look at the following thread: Unofficial PicoCalc PicoMite/WebMite firmware release thread (V6.00.02). It will give you a lot of information on using MMBasic on the PicoCalc. Note that the version of MMBasic that comes with the PicoCalc is old, and its use is not recommended; you should use the latest version of MMBasic 6.00.02 modified to run on the PicoCalc as mentioned in that thread. Also, you may want to update the firmware on your PicoCalc’s STM32 to help resolve some keyboard issues.
