Looking for an SSH and serial console to use with my a06 on Armbian or Manjaro, need to be able to connect to network switches. I have putty installed, but it doesn’t fit the height of the display.
Is there a way to adjust putty to fit, or is there a different application I can use. Having telnet might be useful, but generally turned off on things due to weak security.
As with many other things, I needed to learn how minicom worked, won’t do ssh, but serial is fine. I may try to tweak PuTTY settings and see if I can shrink the menus down to fit the display. But for now minicom will do what I need.
I did run into a problem with a usb-serial device based on FTDI… It would connect, get assigned to ttyUSB0, then immediately disconnect. A little searching later and the answer was to remove brltty. Reboot and now it stays connected.
