I have no idea how data flashing works on waveshare board, but seems on original one you need to use jumper.
did you remove/flip the jumper/switch that puts the io board in flash mode so it can boot normally?
could it be the case?
Rex
August 14, 2025, 11:09pm
22
Every one I’ve use had a switch or jumper to put it in gadget mode to flash the emmc or sd, and you had to remove it for the device to boot right.
Kyzer
August 17, 2025, 11:26am
23
Thank you all for your help!
What’s next?
WiFi signal is crap and I have 8 WAPs at home…
Rex
August 17, 2025, 11:30am
24
If you stuck the stock antenna to the chassis like the manual says, then that’s the problem. The case interferes with the antenna and causes low performance. Use some thick double sided tape to give it 2mm of separation or get a externally mounted antenna.
Kyzer:
What’s next?
buy point 9: GitHub - cjstoddard/Clockworkpi-uConsole: 10 things to do after you get your ClockworkPi uConsole
Original intro (Outdated)
EDIT
These are some topics that have been getting buried under a lot of new topics, but I think they are useful. Read them CAREFULLY before executing any script or shell command. Understand what they do and decide if you want to do it.
In other words: Use them at your own risk
[Config related]
Keywords: config, getting started, beginning, beginner, first steps, config.txt
Chris Stoddard’s guide, updated with CM5 info (taken from the very first reply to this thread…
