i finally received my AIO board and had good fun getting all services running.
Meshtastic
GPS with gpsshare and GPSD
TAR1090
SDR
etc etc.
I noticed that for meshtastic, even though i have set the GPS to the right port (e.g. /dev/ttyS0), it doesn’t seem to pick up the position of the device. The settings seems to indicate a “pin”. I am able to retrieve proper positioning directly though. i can manually feed the position to meshtastic via the commandline. Has anyone gotten meshtastic on uConsole to work with GPS position?
Hi @Rex… thanks for the pointer. i have GPS in meshtastic web set to “Smart Position”->ON
GPS “Enabled” form Meshtastic Web. But looking at the Meshtastic MUI, the position says “00. 00”. is that the same for what you have tried?
ah i figured out why… it seems that meshtasticd needs to directly probe the port and does not respond to just devices producing NEMA sentences… i have to shut down pygpsclient before being able to use it!
