Updated Images for new uConsole screens
@Rex Just wanted to say thanks for the work with the OS images.
really awersome work :love_you_gesture:
I got my Uconsole about a week ago now and installed Debian 13 Trixie on it with a CM5 4GB wifi lite.
I could not help my self and wanted KDE instead of Gnome or what ever the standard is that is installed.
But when using SDDM for the login screen everything was rotated 90 degrees to the right, but after login everything was OK again.
Any way long story short… I used what an old fart like me could remember about SDDM config and Claude.ai and made a small script for rotating the SDDM login screen.
not sure if others have this problem or just me because of KDE :wink:
but anyway the script / info about the rotation can be found here.
Yeah the screen is native portrait so any new software you installed that isn’t already configured we’ll use the screen as portrait instead of landscape. But changing the login screen desktop or CLI is literally just change in a config file somewhere.
linux was explained!
i have similar behaivior with high contrast i dont remeber when i see these but are less visible in low bright configuration, not sure if are normal degradation or screen function
I am having an issue with new replacement screen that was sent to me because my unit had a bad screen see pictures below. Top picture is my old screen from a older Uconsole which looks fine. Now look at the replacement screen at the bottom it’s really washed out and badly calibrated I have sent these pictures to Alex to investigate the issue.
I installed kali form rex link. All works fine but some disturbance sound came, Don’t figure out what is this?
cm5, battery level below 50%?
Yest its off after charging, maybe isse is there.
Thkans.
Sorry but issue is related to power but not fix yet, annoying sound came and while play video device turn off, work fine while plugin mode.
