For those of you that have recently received a new uConsole. I’ve updated most my images to work with the new screen. I still have a couple to do but the updated ones are labeled with kernel 6.12.67.
Updated ones:
Debian 12 Bookworm
Debian 13 Trixie
DragonOS
Kali 2026.2
ParrotOS
RetroPie
TwisterOS
Ubuntu 24.04
The images can be found here and discussions in their respective forum threads.
Hi Rex, thanks for your work! I have a problem. I wanted to test the new Kali image, but the screen stays off! The backlight comes on, but that’s it! I think it’s booting, but the display isn’t working! It works with the 6.12.34 image! It would be great if you could check what the problem is. Thanks
Hey Rex, I figured out why Kali wasn’t booting. I installed Kali on the NVMe drive. With the new image, you modified the config.txt file so the SSD would be recognized (pciex1). I had to disable that again to boot the new Kali from the SD card. Sorry for bothering you.
