I upgraded my uconsole to a cm5 lite 4gb from a cm4 also got the adapter board and the battery adapter with nvme slot using a gen 3 nvme ssd and it is slower than when I had a cm4 with a sd card. Any help or wisdom would be appreciated.
what do you mean? slower UI, slower file operations, slower booting time?
can you please run in the console free -wh and put there result?
is it hot?
Did you try to underclock your cm5? Do you have in your /boot/firmware/config.txt something like it:
( Overclocking and *Underclocking* the Raspberry Pi 5 - Jeff Geerling )
# Tell the DVFS algorithm to increase voltage by this amount (in µV; default 0).
# IMPORTANT: See note below
over_voltage_delta=50000
# Set the Arm A76 core frequency (in MHz; default 2400).
arm_freq=3000
# Set the VideoCore VII core frequency (in MHz; default 800).
gpu_freq=1000
Alright so I think I made a mistake when I was setting it up when you boot for the first time I was letting it update the image I got from Rex and updating it to something that wasn’t truly optimized for the uconsole so I tried doing with out that and it seems like it’s running as I would expect sorry for the confusion
But to try to answer you the best I can it wasn’t running hot only around 40 degrees. everything was slower opening any app took forever.
