Webmite Pico2W WIFI Control
I’m running the 2W module with the Webmite Pico2W V6.00.03 firmware. I successfully connected to my home wifi using the OPTION WIFI [SSID], [password] command in MMBASIC, and that flag is set so that now I connect whenever the device is powered up. My question is how can I reset/remove that flag? I’ve tried searching through the documentation, but–short of wiping the firmware and reinstalling–haven’t found a way to turn off the wifi which draws quite a bit more power.
Am I missing something allowing me to edit the OPTIONS list, or does anyone have any tips?
(post deleted by author)
OPTION RESET will clear all options but leave the firmware intact
Thank you. I also figured out that OPTION WIFI “”, “” shuts down the wifi.
