I received a replacement screen, from Alex of Clockwork(thank you), after having broken it while updating the firmware. And in order to not need another on. I have purchased this 40pin wide ZIF this fits the Pico but is one row to narrow so I intend to solder it to theses Right angle headers with probably some JB weld to strength it up. and then a new back case.
I am waiting on my headers in the mail to assemble and try it. I can see wanting to swap brains, to for different projects, and hope this will minimize wear on the connector. I’ll follow up with how well this works.
I assuming that the adapter will be too high for the existing back, and a new back will have to be 3D printed. I might find a useful software configuration I want to stick with, in which case I’ll remove the adapter, and go for the existing “sleek” case. I am assuming that for some definition of long term the ZIF won’t be a reliable socket to use.
Mine did get much easier after a few cycles. The first insert was quite a crack, thought I’d bust the LCD beneath . The problem with zif sockets is that the current one is surface mounted .
