Ther is a lot of info… and im giving you a lot to go thru… but it is my hope that after all this, you should feel al little more comfortable make a decision. If after all this study, you still have queries, I invite you to ask and we can start discourse.
This is not as easy to answer as simply saying this is the best brand and model, Unfortunately. 18650 batteries come in a variety of chemistries and some offer protection circuits while others do not. I think this is important enough to not just state, but to do so while making extra effort to make a point. I will highly recommend you study up some. Everyone here will recommend that if you are new, opt for protected cells. These cells sacrifice a tiny bit of capacity to store a chip that prevent…
18650 is a size declaration. HOWEVER, Not all 18650s are 650mm x 18mm. some may be 17600 or even 19700. Make sure the SPECIFICATIONS of the batteries you choose match what the DT battery clip says it can fit.
Unprotected cells may fit better but you MUST BE CAREFUL when putting them in as polarity is EXTREMLY IMPORTANT and reversing this may cause detriment to the battery, the device or both.
[18650 Safety - Some things to know when handling using bare lithium-ion cells]
Any cells…
