So In purchasing a set of protected batteries, I noted that it does fit inside the DevTerm, however because the battery diameter is slightly larger than what the cover supports, the battery door does close, but causes the entire back case to slightly bow, meaning the shell starts to separate from the front housing on the top of the unit (the plastic tab no longer catches the faceplate).
So my question is, was the DevTerm specifically designed for unprotected batteries, which mostly fit inside the DevTerm fine without pushing the size limit of the battery compartment? Or is using such batteries unstafe (even if being left in the device all the time - On/off/charging)?
Just for an example, I’m using Samsung 35E 18650 3500mAh 8A - Protected batteries. They fit without any bowing/deformation of the chassis. They are very snug, but have showed no problems in 4 days of semi-frequent use (2-4 hours per day). They have been charged once per day.
