Anybody thought of this
Screen is 2.5 x 0.4cm
And res is 40x250
What part number and how would you hook it up?
Part number:SKU 26783 for 64x32 screen but dont fit.
0.2 inch 14-egemnt display doent exist
0.2 inch 7 segment pack is impissuble to tell which number it is
So we hook 2 pack of 3 or 4 0.2 inch 7 seg displays togeter
I dont know how to connect cuz im dumb but its properly a little .uf2 making and a 2-1 multiplexer theres more info on here Reddit - Please wait for verification
Hardware code for 64x32 screen maybe
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 64 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
#define OLED_RESET -1 // Reset pin #
#define SCREEN_ADDRESS2 0x3D // Found using scanner. I changed the address switch on the PIICODev OLED to on
//Initialize OLED screens.
Adafruit_SSD1306 display1(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
Adafruit_SSD1306 display2(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
int t1 = 0, t2 = 0;
void setup() {
//— Screens ------------------------------------------------
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
if (!display1.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS1)) {
Serial.println(F(“SSD1306 allocation failed”));
for (;;); // Don’t proceed, loop forever
if (!display2.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS2)) {
//default I2C pins GP4, GP5. These are pins 6 and 7 on the Pico
Serial.println(SDA);
Serial.println(SCL);
Since the back cover is transparent, placing it at the top seems more harmonious and also avoids destructive modification.
imagination picture with nano bananer
v
I recommended to make the code in tunning in the stm32 chip so it doesnt affects the picos performance and get screen manufacturers to make the screen
is that your actual PicoCalc?
mine has a black transparant case, yours much nicer
“imagination picture with nano bananer”
