I cannot get my 4G modem working - I have been following every step in this guide How to use the 4G extension · clockworkpi/uConsole Wiki · GitHub but no success. Clockwork support suspected hw issues and I was provided with a new 4G modem but same issues as before. I have been trying out multiple images and are currently using the clockwork lite image. Everything else is working perfect, also the speakers.
I run this command: uconsole-4g-cm4 enable
Then I run this command: echo -en “AT+CUSBPIDSWITCH?\r\n” | sudo socat - /dev/ttyUSB2,crnl
But get no response at all.
When I run: sudo mmcli -L
No modem is present.
I have not seen any light on the 4G modem turn green when I run the uconsole-4g-cm4 enable.
I have understood that the modem should show up as a USB device but when I run lsusb I cannot see any modem
Any help with further troubleshooting is highly appreciated.
To rule out any issues with batteries, I have also tested while on external power.
if you have a cm4… the uconsole images have that script pre-installed… when you type “uconsole-4g-cm4 enable” it should respond with “powering on 4g” if it does not respond… you have other problems besides the 4g modem…
i am using ; http://dl.clockworkpi.com/uConsole_CM4_v0.1b_xfce_64bit.img.7z and this works fine.
Thanks for the support - I’m currently using same image as you (and have been trying several others) but all give the same result. It does reply with Powering on 4G modem and that I should use mmcli -L to lview modem but no success.
I’m starting to suspect that there is some issue with the expansion port causing the 4G card not to operate at all. However, the speakers work fine so there is at least some connection.
If it powers on the 4g modem, and you wait 20s then restart mm service… and still see nothing, you most likely have an issue. since this is your second card… I would think maybe the issue is elsewhere… like the ext connector.
Yes, that what I was starting to suspect as well. Is there any way to further troubleshoot that - like checking if there are any signal on the uart on the extension board?
Dippending on your comfort in testing electronics, you are in luck! the GitHub has a full schematic that you can use to troubleshoot voltage and resistance on all cpi provided boards. Beyond that, using metal probes on live circuits always has various dangers and pitfalls. If you are not fully confident in this, it is best to leave it to professionals.
