4G module won’t work
Hey all,
Doesn’t matter what I’ve tried, it just won’t work!:frowning:
Would love some help with this, please.
Tried on both provided image from GitHub.
Are you sure it doesn’t matter what you tried? Not even from the very site you got those images from?
You people keep asking without browsing whether or not somebody else asked the same question as you.
Since I’m a new user in here, I was unable to post more pictures.
Yes, I’m sure. I’ve searched, both in here and on GitHub, and didn’t get any 4G connection.
Hmm, yeah. Now that’s odd. What’s the signal bars on the top right mean? Is the module flashing an LED or something? Have you looked into dmesg or journalctl for clues on what went wrong?
Try to be more descriptive of your situation next time. Saying “you’ve tried everything” or the like without summarizing which ones you did will give the wrong impression.
Ye, you’re right. Was really frustrated and hungry after 2 hours of trying.
The signal bars are for WiFi.
Board it self doesn’t blink at all.
lsusb displayed it on 9001 but only once, and never again.
Not familiar with the two commends you mentioned, will try once I get back home and report back.
Thanks!
Not blinking? Either of the 4g-enable commands should cause the LED in the module to light up, at least that’s how I understood it. Seems to me like it is defective. Does sound play in your device? (I ask this because the speakers are connected via the extension module.)
doesnt blink at all. speakers does work!
cpi@uConsole:~ $ uconsole-4g-cm4 enable
Power on 4G module on uConsole cm4
waiting…
done
use mmcli -L to see 4G modem or not
cpi@uConsole:~ $ echo -en “AT+CUSBPIDSWITCH?\r\n” | sudo socat - /dev/ttyUSB2,crnl
cpi@uConsole:~ $ sudo ifconfig
eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether d8:3a:dd:b7:92:bf txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1000 (Local Loopback)
RX packets 81 bytes 10143 (9.9 KiB)
TX packets 81 bytes 10143 (9.9 KiB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.8.245 netmask 255.255.255.0 broadcast 192.168.8.255
inet6 fe80::bc9a:eba4:3e3f:c173 prefixlen 64 scopeid 0x20
ether d8:3a:dd:b7:92:c1 txqueuelen 1000 (Ethernet)
RX packets 73796 bytes 98719416 (94.1 MiB)
TX packets 34333 bytes 3938030 (3.7 MiB)
cpi@uConsole:~ $ mmcli -L
No modems were found
cpi@uConsole:~ $ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
[ 0.000000] Linux version 5.10.17-v8+ (cpi@cpi-X79) (aarch64-linux-gnu-gcc (Ubuntu 11.3.0-1ubuntu1~22.04) 11.3.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #5 SMP PREEMPT Thu Jun 29 13:36:01 CST 2023
[ 0.000000] Machine model: Raspberry Pi Compute Module 4 Rev 1.1
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000016c00000, size 384 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000003fffffff]
[ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000fbffffff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x00000000fbffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
[ 0.000000] On node 0 totalpages: 1012736
[ 0.000000] DMA zone: 3792 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 242688 pages, LIFO batch:63
[ 0.000000] DMA32 zone: 12032 pages used for memmap
[ 0.000000] DMA32 zone: 770048 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 32 pages/cpu s91224 r8192 d31656 u131072
[ 0.000000] pcpu-alloc: s91224 r8192 d31656 u131072 alloc=32*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Spectre-v2
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 996912
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 8250.nr_uarts=0 smsc95xx.macaddr=D8:3A:DD:B7:92:BF vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=8932d4f5-02 rootfstype=ext4 fsck.repair=yes rootwait
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x0000000037400000-0x000000003b400000] (64MB)
[ 0.000000] Memory: 3489232K/4050944K available (11200K kernel code, 1920K rwdata, 3956K rodata, 3648K init, 1242K bss, 168496K reserved, 393216K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 35286 entries in 138 pages
[ 0.000000] ftrace: allocated 138 pages with 3 groups
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 10)
[ 0.000000] random: get_random_bytes called from start_kernel+0x3bc/0x57c with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000006] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000257] Console: colour dummy device 80x25
[ 0.000766] printk: console [tty1] enabled
[ 0.000825] Calibrating delay loop (skipped), value calculated using timer frequency… 108.00 BogoMIPS (lpj=216000)
[ 0.000867] pid_max: default: 32768 minimum: 301
[ 0.001016] LSM: Security Framework initializing
[ 0.001249] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.001330] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.002721] Disabling memory control group subsystem
[ 0.004979] rcu: Hierarchical SRCU implementation.
[ 0.006021] EFI services will not be available.
[ 0.006546] smp: Bringing up secondary CPUs …
[ 0.007554] Detected PIPT I-cache on CPU1
[ 0.007630] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
[ 0.008800] Detected PIPT I-cache on CPU2
[ 0.008849] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
[ 0.009937] Detected PIPT I-cache on CPU3
[ 0.009984] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
[ 0.010132] smp: Brought up 1 node, 4 CPUs
[ 0.010218] SMP: Total of 4 processors activated.
[ 0.010241] CPU features: detected: 32-bit EL0 Support
[ 0.010264] CPU features: detected: CRC32 instructions
[ 0.010286] CPU features: detected: 32-bit EL1 Support
[ 0.043503] CPU: All CPU(s) started at EL2
[ 0.043583] alternatives: patching kernel code
[ 0.045126] devtmpfs: initialized
[ 0.055349] Enabled cp15_barrier support
[ 0.055411] Enabled setend support
[ 0.055623] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.055667] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.065413] pinctrl core: initialized pinctrl subsystem
[ 0.066212] DMI not present or invalid.
[ 0.066577] NET: Registered protocol family 16
[ 0.069538] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.069829] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.070750] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.070857] audit: initializing netlink subsys (disabled)
[ 0.071227] audit: type=2000 audit(0.068:1): state=initialized audit_enabled=0 res=1
[ 0.071705] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.072186] cpuidle: using governor menu
[ 0.072386] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.072568] ASID allocator initialised with 65536 entries
[ 0.072699] Serial: AMBA PL011 UART driver
[ 0.116178] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.124387] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-03-17T10:50:39, variant start
[ 0.128396] raspberrypi-firmware soc:firmware: Firmware hash is 82f3750a65fadae9a38077e3c2e217ad158c8d54
[ 0.160647] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.164603] vgaarb: loaded
[ 0.165043] SCSI subsystem initialized
[ 0.165259] usbcore: registered new interface driver usbfs
[ 0.165323] usbcore: registered new interface driver hub
[ 0.165396] usbcore: registered new device driver usb
[ 0.165785] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.167375] clocksource: Switched to clocksource arch_sys_counter
[ 1.182911] VFS: Disk quotas dquot_6.6.0
[ 1.183034] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.183213] FS-Cache: Loaded
[ 1.183499] CacheFiles: Loaded
[ 1.193788] NET: Registered protocol family 2
[ 1.194967] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 1.195037] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 1.195274] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 1.195773] TCP: Hash tables configured (established 32768 bind 32768)
[ 1.196024] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 1.196109] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 1.196446] NET: Registered protocol family 1
[ 1.197380] RPC: Registered named UNIX socket transport module.
[ 1.197407] RPC: Registered udp transport module.
[ 1.197427] RPC: Registered tcp transport module.
[ 1.197447] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.197478] PCI: CLS 0 bytes, default 64
[ 1.199798] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 1.200110] kvm [1]: IPA Size Limit: 44 bits
[ 1.201266] kvm [1]: vgic interrupt IRQ9
[ 1.201556] kvm [1]: Hyp mode initialized successfully
[ 1.204029] Initialise system trusted keyrings
[ 1.204374] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 1.210574] zbud: loaded
[ 1.212310] FS-Cache: Netfs ‘nfs’ registered for caching
[ 1.212967] NFS: Registering the id_resolver key type
[ 1.213022] Key type id_resolver registered
[ 1.213043] Key type id_legacy registered
[ 1.213165] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.214258] Key type asymmetric registered
[ 1.214284] Asymmetric key parser ‘x509’ registered
[ 1.214341] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.214602] io scheduler mq-deadline registered
[ 1.214626] io scheduler kyber registered
[ 1.219061] gpio-507 (ant1): hogged as output/high
[ 1.220481] gpio-511 (ant2): hogged as output/low
[ 1.221817] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.221858] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.221943] brcm-pcie fd500000.pcie: MEM 0x0600000000…0x063fffffff → 0x00c0000000
[ 1.222032] brcm-pcie fd500000.pcie: IB MEM 0x0000000000…0x00ffffffff → 0x0400000000
[ 1.539394] brcm-pcie fd500000.pcie: link down
[ 1.547663] iproc-rng200 fe104000.rng: hwrng registered
[ 1.548048] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.549054] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.549461] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 1.560370] brd: module loaded
[ 1.572651] loop: module loaded
[ 1.574375] Loading iSCSI transport class v2.0-870.
[ 1.576698] libphy: Fixed MDIO Bus: probed
[ 1.578413] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.591399] libphy: bcmgenet MII bus: probed
[ 1.639512] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.640543] PPP generic driver version 2.4.2
[ 1.640771] PPP BSD Compression module registered
[ 1.640796] PPP Deflate Compression module registered
[ 1.640826] PPP MPPE Compression module registered
[ 1.640851] NET: Registered protocol family 24
[ 1.640951] usbcore: registered new interface driver r8152
[ 1.641030] usbcore: registered new interface driver lan78xx
[ 1.641095] usbcore: registered new interface driver smsc95xx
[ 1.641750] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.642090] dwc_otg: FIQ enabled
[ 1.642101] dwc_otg: NAK holdoff enabled
[ 1.642110] dwc_otg: FIQ split-transaction FSM enabled
[ 1.642124] Module dwc_common_port init
[ 1.642594] usbcore: registered new interface driver uas
[ 1.642671] usbcore: registered new interface driver usb-storage
[ 1.642893] mousedev: PS/2 mouse device common for all mice
[ 1.645951] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.649352] sdhci: Secure Digital Host Controller Interface driver
[ 1.649381] sdhci: Copyright(c) Pierre Ossman
[ 1.650100] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 1.650689] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.653613] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.653882] hid: raw HID events driver (C) Jiri Kosina
[ 1.654034] usbcore: registered new interface driver usbhid
[ 1.654056] usbhid: USB HID core driver
[ 1.662142] Initializing XFRM netlink socket
[ 1.662208] NET: Registered protocol family 17
[ 1.662333] Key type dns_resolver registered
[ 1.662745] registered taskstats version 1
[ 1.662791] Loading compiled-in X.509 certificates
[ 1.663309] Key type ._fscrypt registered
[ 1.663334] Key type .fscrypt registered
[ 1.663391] Key type fscrypt-provisioning registered
[ 1.674527] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.674838] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.674943] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 23, base_baud = 0) is a PL011 rev2
[ 1.681261] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.683640] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.683670] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.713518] of_cfs_init
[ 1.713665] of_cfs_init: OK
[ 1.726911] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.728591] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.730268] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.733257] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.734932] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.747083] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 1.747915] Waiting for root device PARTUUID=8932d4f5-02…
[ 1.774826] random: fast init done
[ 1.800079] mmc1: new high speed SDIO card at address 0001
[ 1.850294] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
[ 1.851264] mmcblk0: mmc0:aaaa SD32G 29.7 GiB
[ 1.853670] mmcblk0: p1 p2
[ 1.869556] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.869673] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.875281] devtmpfs: mounted
[ 1.883225] Freeing unused kernel memory: 3648K
[ 1.883457] Run /sbin/init as init process
[ 1.883477] with arguments:
[ 1.883488] /sbin/init
[ 1.883497] with environment:
[ 1.883507] HOME=/
[ 1.883516] TERM=linux
[ 2.259780] systemd[1]: System time before build time, advancing clock.
[ 2.349912] NET: Registered protocol family 10
[ 2.351683] Segment Routing with IPv6
[ 2.398074] systemd[1]: systemd 247.3-7+deb11u4 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 2.399045] systemd[1]: Detected architecture arm64.
[ 2.418450] systemd[1]: Set hostname to .
[ 3.043992] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd’s process lifecycle management for the service. Please update your service to use a safer KillMode=, such as ‘mixed’ or ‘control-group’. Support for KillMode=none is deprecated and will eventually be removed.
[ 3.276930] systemd[1]: Queued start job for default target Multi-User System.
[ 3.278550] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.280749] systemd[1]: Created slice system-modprobe.slice.
[ 3.281493] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.282457] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 3.282867] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.283672] systemd[1]: Created slice User and Session Slice.
[ 3.284562] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.285957] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.286682] systemd[1]: Reached target Slices.
[ 3.287149] systemd[1]: Reached target Swap.
[ 3.291823] systemd[1]: Listening on Syslog Socket.
[ 3.292922] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 3.293674] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 3.299456] systemd[1]: Listening on Journal Audit Socket.
[ 3.300595] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.301868] systemd[1]: Listening on Journal Socket.
[ 3.303887] systemd[1]: Listening on udev Control Socket.
[ 3.305000] systemd[1]: Listening on udev Kernel Socket.
[ 3.306149] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 3.309958] systemd[1]: Mounting POSIX Message Queue File System…
[ 3.314609] systemd[1]: Mounting RPC Pipe File System…
[ 3.320021] systemd[1]: Mounting Kernel Debug File System…
[ 3.325513] systemd[1]: Mounting Kernel Trace File System…
[ 3.326545] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 3.332389] systemd[1]: Starting Restore / save the current clock…
[ 3.337301] systemd[1]: Starting Set the console keyboard layout…
[ 3.342616] systemd[1]: Starting Create list of static device nodes for the current kernel…
[ 3.348470] systemd[1]: Starting Load Kernel Module configfs…
[ 3.354334] systemd[1]: Starting Load Kernel Module drm…
[ 3.361122] systemd[1]: Starting Load Kernel Module fuse…
[ 3.364632] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 3.369444] systemd[1]: Starting File System Check on Root Device…
[ 3.382418] systemd[1]: Starting Journal Service…
[ 3.406609] systemd[1]: Starting Load Kernel Modules…
[ 3.414710] systemd[1]: Starting Coldplug All udev Devices…
[ 3.428916] fuse: init (API version 7.32)
[ 3.434738] systemd[1]: Mounted POSIX Message Queue File System.
[ 3.435993] systemd[1]: Mounted RPC Pipe File System.
[ 3.437074] systemd[1]: Mounted Kernel Debug File System.
[ 3.438149] systemd[1]: Mounted Kernel Trace File System.
[ 3.440249] systemd[1]: Finished Restore / save the current clock.
[ 3.443228] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 3.449605] systemd[1]: modprobe@configfs.service: Succeeded.
[ 3.451216] systemd[1]: Finished Load Kernel Module configfs.
[ 3.454874] systemd[1]: modprobe@drm.service: Succeeded.
[ 3.456482] systemd[1]: Finished Load Kernel Module drm.
[ 3.458784] systemd[1]: modprobe@fuse.service: Succeeded.
[ 3.460090] systemd[1]: Finished Load Kernel Module fuse.
[ 3.466996] systemd[1]: Mounting FUSE Control File System…
[ 3.473083] systemd[1]: Mounting Kernel Configuration File System…
[ 3.478772] systemd[1]: Started File System Check Daemon to report status.
[ 3.488156] systemd[1]: Finished Load Kernel Modules.
[ 3.489642] systemd[1]: Mounted FUSE Control File System.
[ 3.494705] systemd[1]: Mounted Kernel Configuration File System.
[ 3.500332] systemd[1]: Starting Apply Kernel Variables…
[ 3.588164] systemd[1]: Finished File System Check on Root Device.
[ 3.590698] systemd[1]: Finished Apply Kernel Variables.
[ 3.607715] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 3.676246] systemd[1]: Started Journal Service.
[ 3.731624] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.784814] systemd-journald[130]: Received client request to flush runtime journal.
[ 3.804814] systemd-journald[130]: File /var/log/journal/45b6947c369a9ff67ede76ae64d0adf0/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 4.831900] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[ 4.832579] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[ 4.835553] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[ 4.836206] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[ 4.910452] spi-bcm2835 fe204000.spi: prop pinctrl-0 index 1 invalid phandle
[ 4.910511] spi-bcm2835: probe of fe204000.spi failed with error -22
[ 4.911025] spi-bcm2835 fe204800.spi: no tx-dma configuration found - not using dma mode
[ 4.916029] axp20x-i2c 0-0034: AXP20x variant AXP223 found
[ 4.954053] mc: Linux media interface: v0.10
[ 4.981892] videodev: Linux video capture interface: v2.00
[ 4.982470] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.989278] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 5.035108] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.052759] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 5.052788] [vc_sm_connected_init]: start
[ 5.059690] [vc_sm_connected_init]: installed successfully
[ 5.067590] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.084582] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.088148] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.096539] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.120646] input: axp20x-pek as /devices/platform/soc/fe205000.i2c/i2c-0/0-0034/axp221-pek/input/input0
[ 5.120855] brcmstb-i2c fef04500.i2c: @97500hz registered in polling mode
[ 5.125118] brcmstb-i2c fef09500.i2c: @97500hz registered in polling mode
[ 5.132034] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 5.132103] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 5.132402] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 5.133047] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 5.133527] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 5.133863] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 5.133891] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 5.133914] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 5.133932] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 5.133958] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 5.134160] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 5.138662] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 5.138712] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 5.143229] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 5.143278] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 5.227402] dwc2 fe980000.usb: supply vusb_d not found, using dummy regulator
[ 5.227699] dwc2 fe980000.usb: supply vusb_a not found, using dummy regulator
[ 5.263504] Registered IR keymap rc-cec
[ 5.263738] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 5.264018] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input1
[ 5.269929] debugfs: Directory ‘fef00700.hdmi’ with parent ‘vc4-hdmi-0’ already present!
[ 5.271496] vc4_hdmi fef00700.hdmi: ASoC: no DMI vendor name!
[ 5.272447] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[ 5.276298] Registered IR keymap rc-cec
[ 5.276486] rc rc1: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[ 5.276704] input: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input2
[ 5.277759] debugfs: Directory ‘fef05700.hdmi’ with parent ‘vc4-hdmi-1’ already present!
[ 5.278709] vc4_hdmi fef05700.hdmi: ASoC: no DMI vendor name!
[ 5.279595] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[ 5.284293] dwc2 fe980000.usb: DWC OTG Controller
[ 5.284341] dwc2 fe980000.usb: new USB bus registered, assigned bus number 1
[ 5.284409] dwc2 fe980000.usb: irq 28, io mem 0xfe980000
[ 5.286724] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 5.286744] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.286757] usb usb1: Product: DWC OTG Controller
[ 5.286769] usb usb1: Manufacturer: Linux 5.10.17-v8+ dwc2_hsotg
[ 5.286781] usb usb1: SerialNumber: fe980000.usb
[ 5.291954] hub 1-0:1.0: USB hub found
[ 5.292732] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.294725] hub 1-0:1.0: 1 port detected
[ 5.380903] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 5.403104] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 5.434586] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 5.447667] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.447686] axp22x-adc: Failed to locate of_node [id: -1]
[ 5.448545] usbcore: registered new interface driver brcmfmac
[ 5.477264] dcdc1: supplied by regulator-dummy
[ 5.482043] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 1
[ 5.495116] dcdc2: supplied by regulator-dummy
[ 5.509896] dcdc3: supplied by regulator-dummy
[ 5.536105] dcdc4: supplied by regulator-dummy
[ 5.548113] Registered IR keymap rc-cec
[ 5.548321] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 5.548509] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input3
[ 5.549341] debugfs: Directory ‘fef00700.hdmi’ with parent ‘vc4-hdmi-0’ already present!
[ 5.550519] dcdc5: supplied by regulator-dummy
[ 5.550891] vc4_hdmi fef00700.hdmi: ASoC: no DMI vendor name!
[ 5.551163] dc1sw: supplied by dcdc1
[ 5.558057] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[ 5.576386] Registered IR keymap rc-cec
[ 5.576633] rc rc1: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[ 5.576844] input: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input4
[ 5.577724] debugfs: Directory ‘fef05700.hdmi’ with parent ‘vc4-hdmi-1’ already present!
[ 5.578751] vc4_hdmi fef05700.hdmi: ASoC: no DMI vendor name!
[ 5.579622] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[ 5.587017] dc5ldo: supplied by dcdc5
[ 5.612643] audio-vdd: supplied by regulator-dummy
[ 5.664284] display-vcc: supplied by regulator-dummy
[ 5.687218] aldo3: supplied by regulator-dummy
[ 5.695458] usb 1-1: new high-speed USB device number 2 using dwc2
[ 5.736870] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.744050] eldo1: supplied by regulator-dummy
[ 5.744411] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov 1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[ 5.761303] eldo2: supplied by regulator-dummy
[ 5.775860] eldo3: supplied by regulator-dummy
[ 5.790284] dldo1: supplied by regulator-dummy
[ 5.804349] dldo2: Bringing 700000uV into 3300000-3300000uV
[ 5.823484] random: crng init done
[ 5.823510] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.840448] dldo2: supplied by regulator-dummy
[ 5.854527] dldo3: Bringing 700000uV into 3300000-3300000uV
[ 5.892660] dldo3: supplied by regulator-dummy
[ 5.906746] dldo4: Bringing 700000uV into 3300000-3300000uV
[ 5.910942] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.38
[ 5.910969] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 5.910983] usb 1-1: Product: USB2.0 Hub
[ 5.914858] hub 1-1:1.0: USB hub found
[ 5.919213] hub 1-1:1.0: 4 ports detected
[ 5.939804] dldo4: supplied by regulator-dummy
[ 5.939887] Registered IR keymap rc-cec
[ 5.940062] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 5.940268] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input5
[ 5.940323] rtc_ldo: supplied by regulator-dummy
[ 5.941147] debugfs: Directory ‘fef00700.hdmi’ with parent ‘vc4-hdmi-0’ already present!
[ 5.942828] vc4_hdmi fef00700.hdmi: ASoC: no DMI vendor name!
[ 5.944022] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[ 5.956753] ldo_io0: supplied by regulator-dummy
[ 5.957190] Registered IR keymap rc-cec
[ 5.957359] rc rc1: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[ 5.957566] input: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input6
[ 5.958502] debugfs: Directory ‘fef05700.hdmi’ with parent ‘vc4-hdmi-1’ already present!
[ 5.959760] vc4_hdmi fef05700.hdmi: ASoC: no DMI vendor name!
[ 5.959949] adc081c 1-0054: supply vref not found, using dummy regulator
[ 5.960626] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[ 5.971694] ldo_io1: supplied by regulator-dummy
[ 5.972619] axp20x-usb-power-supply: Failed to locate of_node [id: -1]
[ 5.972981] axp20x-i2c 0-0034: AXP20X driver loaded
[ 5.973288] bcm2708_i2c fe205000.i2c: BSC0 Controller at 0xfe205000 (irq 25) (baudrate 100000)
[ 6.098864] Registered IR keymap rc-cec
[ 6.099077] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 6.099285] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input7
[ 6.102865] debugfs: Directory ‘fef00700.hdmi’ with parent ‘vc4-hdmi-0’ already present!
[ 6.115165] vc4_hdmi fef00700.hdmi: ASoC: no DMI vendor name!
[ 6.118284] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[ 6.130911] Registered IR keymap rc-cec
[ 6.131119] rc rc1: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[ 6.131316] input: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input8
[ 6.135114] debugfs: Directory ‘fef05700.hdmi’ with parent ‘vc4-hdmi-1’ already present!
[ 6.139187] vc4_hdmi fef05700.hdmi: ASoC: no DMI vendor name!
[ 6.142207] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[ 6.215460] usb 1-1.1: new full-speed USB device number 3 using dwc2
[ 6.285589] Registered IR keymap rc-cec
[ 6.285820] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 6.286041] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input9
[ 6.287508] debugfs: Directory ‘fef00700.hdmi’ with parent ‘vc4-hdmi-0’ already present!
[ 6.291882] vc4_hdmi fef00700.hdmi: ASoC: no DMI vendor name!
[ 6.292797] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[ 6.296473] Registered IR keymap rc-cec
[ 6.296717] rc rc1: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[ 6.296948] input: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input10
[ 6.298365] debugfs: Directory ‘fef05700.hdmi’ with parent ‘vc4-hdmi-1’ already present!
[ 6.299658] vc4_hdmi fef05700.hdmi: ASoC: no DMI vendor name!
[ 6.300606] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[ 6.301981] vc4-drm gpu: bound fe700000.dsi (ops vc4_dsi_ops [vc4])
[ 6.302284] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 6.302633] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
[ 6.302916] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 6.303201] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 6.303569] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 6.303799] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 6.304086] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 6.317350] usb 1-1.1: New USB device found, idVendor=1eaf, idProduct=0003, bcdDevice= 2.01
[ 6.317368] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6.317383] usb 1-1.1: Product: Maple 003
[ 6.317396] usb 1-1.1: Manufacturer: LeafLabs
[ 6.317408] usb 1-1.1: SerialNumber: LLM 003
[ 6.348831] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 0
[ 6.350834] ------------[ cut here ]------------
[ 6.350982] WARNING: CPU: 0 PID: 154 at drivers/gpu/drm/drm_mode_object.c:45 drm_mode_object_add+0x94/0xa0 [drm]
[ 6.350990] Modules linked in: panel_cwu50 ti_adc081c industrialio_triggered_buffer kfifo_buf industrialio brcmfmac brcmutil sha256_generic v3d cfg80211 rfkill gpu_sched raspberrypi_hwmon dwc2 roles i2c_brcmstb bcm2835_codec(C) bcm2835_isp(C) bcm2835_v4l2(C) vc4 videobuf2_vmalloc v4l2_mem2mem bcm2835_mmal_vchiq(C) videobuf2_dma_contig videobuf2_memops videobuf2_v4l2 cec vc_sm_cma(C) videobuf2_common snd_bcm2835(C) drm_kms_helper videodev mc i2c_bcm2708 spi_bcm2835 snd_soc_core snd_compress snd_pcm_dmaengine snd_pcm rpivid_mem snd_timer snd syscopyarea sysfillrect sysimgblt fb_sys_fops uio_pdrv_genirq uio ocp8178_bl fuse drm drm_panel_orientation_quirks backlight ip_tables x_tables ipv6
[ 6.351270] CPU: 0 PID: 154 Comm: kworker/0:2 Tainted: G C 5.10.17-v8+ #5
[ 6.351277] Hardware name: Raspberry Pi Compute Module 4 Rev 1.1 (DT)
[ 6.351303] Workqueue: events deferred_probe_work_func
[ 6.351319] pstate: 60000005 (nZCv daif -PAN -UAO -TCO BTYPE=–)
[ 6.351432] pc : drm_mode_object_add+0x94/0xa0 [drm]
[ 6.351536] lr : drm_property_create+0xec/0x1c0 [drm]
[ 6.351542] sp : ffffffc011c1b630
[ 6.351550] x29: ffffffc011c1b630 x28: 000000000000002a
[ 6.351566] x27: ffffff80468a6198 x26: 0000000000001e00
[ 6.351582] x25: 0000000000001e00 x24: ffffffc008c0ffa0
[ 6.351596] x23: ffffffc008c0ffc8 x22: 0000000000000004
[ 6.351612] x21: 00000000b0b0b0b0 x20: ffffff804780fc10
[ 6.351626] x19: ffffff80468a6000 x18: ffffffffffffffff
[ 6.351640] x17: 0000000000000001 x16: 0000655207f41f84
[ 6.351655] x15: ffffff804780fbf0 x14: ffffffffffffffff
[ 6.351669] x13: ffffff804780fbd4 x12: 0000000000000008
[ 6.351683] x11: 0101010101010101 x10: 7f7f7f7f7f7f7f7f
[ 6.351698] x9 : ffffffc008be0d1c x8 : ffffff804780fd00
[ 6.351712] x7 : 0000000000000000 x6 : 000000000000003f
[ 6.351726] x5 : 0000000000000040 x4 : ffffffc011c1b650
[ 6.351740] x3 : 0000000000000001 x2 : 00000000b0b0b0b0
[ 6.351755] x1 : ffffff804780fc10 x0 : 0000000000000001
[ 6.351770] Call trace:
[ 6.351877] drm_mode_object_add+0x94/0xa0 [drm]
[ 6.351980] drm_property_create+0xec/0x1c0 [drm]
[ 6.352080] drm_property_create_enum+0x38/0xa0 [drm]
[ 6.352181] drm_connector_set_panel_orientation+0xa4/0xc4 [drm]
[ 6.352200] cwu50_get_modes+0x68/0xa4 [panel_cwu50]
[ 6.352301] drm_panel_get_modes+0x30/0x50 [drm]
[ 6.352363] panel_bridge_connector_get_modes+0x24/0x30 [drm_kms_helper]
[ 6.352414] drm_helper_probe_single_connector_modes+0x1b8/0x77c [drm_kms_helper]
[ 6.352521] drm_client_modeset_probe+0x244/0x1070 [drm]
[ 6.352576] __drm_fb_helper_initial_config_and_unlock+0x4c/0x4fc [drm_kms_helper]
[ 6.352627] drm_fbdev_client_hotplug+0x11c/0x22c [drm_kms_helper]
[ 6.352677] drm_fbdev_generic_setup+0xc0/0x1c0 [drm_kms_helper]
[ 6.352715] vc4_drm_bind+0x1e0/0x210 [vc4]
[ 6.352730] try_to_bring_up_master+0x16c/0x1d4
[ 6.352738] component_master_add_with_match+0xc4/0x110
[ 6.352771] vc4_platform_drm_probe+0xd0/0x110 [vc4]
[ 6.352785] platform_drv_probe+0x60/0xc0
[ 6.352793] really_probe+0xec/0x4c0
[ 6.352800] driver_probe_device+0x64/0xcc
[ 6.352809] __device_attach_driver+0xb4/0x110
[ 6.352820] bus_for_each_drv+0x84/0xe0
[ 6.352827] __device_attach+0xe4/0x184
[ 6.352834] device_initial_probe+0x20/0x30
[ 6.352844] bus_probe_device+0xa4/0xb0
[ 6.352855] deferred_probe_work_func+0x80/0xbc
[ 6.352865] process_one_work+0x1dc/0x4bc
[ 6.352873] worker_thread+0x144/0x470
[ 6.352883] kthread+0x14c/0x160
[ 6.352893] ret_from_fork+0x10/0x38
[ 6.352901] —[ end trace 8f4dd16c92812593 ]—
[ 6.353221] ------------[ cut here ]------------
[ 6.353347] WARNING: CPU: 0 PID: 154 at drivers/gpu/drm/drm_mode_object.c:242 drm_object_attach_property+0x78/0xc0 [drm]
[ 6.353353] Modules linked in: panel_cwu50 ti_adc081c industrialio_triggered_buffer kfifo_buf industrialio brcmfmac brcmutil sha256_generic v3d cfg80211 rfkill gpu_sched raspberrypi_hwmon dwc2 roles i2c_brcmstb bcm2835_codec(C) bcm2835_isp(C) bcm2835_v4l2(C) vc4 videobuf2_vmalloc v4l2_mem2mem bcm2835_mmal_vchiq(C) videobuf2_dma_contig videobuf2_memops videobuf2_v4l2 cec vc_sm_cma(C) videobuf2_common snd_bcm2835(C) drm_kms_helper videodev mc i2c_bcm2708 spi_bcm2835 snd_soc_core snd_compress snd_pcm_dmaengine snd_pcm rpivid_mem snd_timer snd syscopyarea sysfillrect sysimgblt fb_sys_fops uio_pdrv_genirq uio ocp8178_bl fuse drm drm_panel_orientation_quirks backlight ip_tables x_tables ipv6
[ 6.353633] CPU: 0 PID: 154 Comm: kworker/0:2 Tainted: G WC 5.10.17-v8+ #5
[ 6.353640] Hardware name: Raspberry Pi Compute Module 4 Rev 1.1 (DT)
[ 6.353660] Workqueue: events deferred_probe_work_func
[ 6.353682] pstate: 60000005 (nZCv daif -PAN -UAO -TCO BTYPE=–)
[ 6.353787] pc : drm_object_attach_property+0x78/0xc0 [drm]
[ 6.353887] lr : drm_connector_set_panel_orientation+0x68/0xc4 [drm]
[ 6.353893] sp : ffffffc011c1b6d0
[ 6.353900] x29: ffffffc011c1b6d0 x28: 000000000000002a
[ 6.353928] x27: ffffff80468a6198 x26: 0000000000001e00
[ 6.353943] x25: 0000000000001e00 x24: ffffffc008c0ffa0
[ 6.353957] x23: ffffffc008ed3028 x22: 0000000000000000
[ 6.353972] x21: ffffff80468a6000 x20: ffffff804780fb80
[ 6.353987] x19: ffffff804437b970 x18: ffffffffffffffff
[ 6.354001] x17: 0000000000000001 x16: 0000655207f41f84
[ 6.354016] x15: ffffff804780fbf0 x14: ffffffffffffffff
[ 6.354030] x13: ffffff804780fbd4 x12: 0000000000000028
[ 6.354045] x11: 0101010101010101 x10: 7f7f7f7f7f7f7f7f
[ 6.354059] x9 : ffffffc008bdc2c8 x8 : ffffff804780ff00
[ 6.354074] x7 : 00000000c0c0c0c0 x6 : 00000000c0c0c0c0
[ 6.354088] x5 : 0000000000000000 x4 : 0000000000000001
[ 6.354102] x3 : 0000000000000006 x2 : 0000000000000003
[ 6.354116] x1 : ffffff804780fc00 x0 : ffffff804437b998
[ 6.354131] Call trace:
[ 6.354236] drm_object_attach_property+0x78/0xc0 [drm]
[ 6.354255] cwu50_get_modes+0x68/0xa4 [panel_cwu50]
[ 6.354355] drm_panel_get_modes+0x30/0x50 [drm]
[ 6.354420] panel_bridge_connector_get_modes+0x24/0x30 [drm_kms_helper]
[ 6.354470] drm_helper_probe_single_connector_modes+0x1b8/0x77c [drm_kms_helper]
[ 6.354575] drm_client_modeset_probe+0x244/0x1070 [drm]
[ 6.354626] __drm_fb_helper_initial_config_and_unlock+0x4c/0x4fc [drm_kms_helper]
[ 6.354676] drm_fbdev_client_hotplug+0x11c/0x22c [drm_kms_helper]
[ 6.354733] drm_fbdev_generic_setup+0xc0/0x1c0 [drm_kms_helper]
[ 6.354770] vc4_drm_bind+0x1e0/0x210 [vc4]
[ 6.354783] try_to_bring_up_master+0x16c/0x1d4
[ 6.354792] component_master_add_with_match+0xc4/0x110
[ 6.354824] vc4_platform_drm_probe+0xd0/0x110 [vc4]
[ 6.354836] platform_drv_probe+0x60/0xc0
[ 6.354844] really_probe+0xec/0x4c0
[ 6.354851] driver_probe_device+0x64/0xcc
[ 6.354859] __device_attach_driver+0xb4/0x110
[ 6.354876] bus_for_each_drv+0x84/0xe0
[ 6.354884] __device_attach+0xe4/0x184
[ 6.354891] device_initial_probe+0x20/0x30
[ 6.354901] bus_probe_device+0xa4/0xb0
[ 6.354911] deferred_probe_work_func+0x80/0xbc
[ 6.354921] process_one_work+0x1dc/0x4bc
[ 6.354929] worker_thread+0x144/0x470
[ 6.354938] kthread+0x14c/0x160
[ 6.354948] ret_from_fork+0x10/0x38
[ 6.354955] —[ end trace 8f4dd16c92812594 ]—
[ 6.462654] axp20x-battery-power-supply axp20x-battery-power-supply: DMA mask not set
[ 6.657814] axp20x-ac-power-supply axp20x-ac-power-supply: DMA mask not set
[ 6.841215] Console: switching to colour frame buffer device 160x45
[ 6.866162] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
[ 6.901302] axp20x-battery-power-supply axp20x-battery-power-supply: couldn’t set constant charge current from DT: fallback to minimum value
[ 7.160505] uart-pl011 fe201000.serial: no DMA platform data
[ 7.287534] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 8.184115] usb 1-1.1: USB disconnect, device number 3
[ 8.423464] usb 1-1.1: new full-speed USB device number 4 using dwc2
[ 8.525044] usb 1-1.1: New USB device found, idVendor=1eaf, idProduct=0024, bcdDevice= 2.00
[ 8.525060] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8.525066] usb 1-1.1: Product: uConsole
[ 8.525072] usb 1-1.1: Manufacturer: ClockworkPI
[ 8.525077] usb 1-1.1: SerialNumber: 20230713
[ 8.528323] input: ClockworkPI uConsole Consumer Control as /devices/platform/soc/fe980000.usb/usb1/1-1/1-1.1/1-1.1:1.0/0003:1EAF:0024.0001/input/input11
[ 8.587756] input: ClockworkPI uConsole Keyboard as /devices/platform/soc/fe980000.usb/usb1/1-1/1-1.1/1-1.1:1.0/0003:1EAF:0024.0001/input/input12
[ 8.588245] input: ClockworkPI uConsole as /devices/platform/soc/fe980000.usb/usb1/1-1/1-1.1/1-1.1:1.0/0003:1EAF:0024.0001/input/input13
[ 8.588396] input: ClockworkPI uConsole Mouse as /devices/platform/soc/fe980000.usb/usb1/1-1/1-1.1/1-1.1:1.0/0003:1EAF:0024.0001/input/input14
[ 8.588636] hid-generic 0003:1EAF:0024.0001: input,hidraw0: USB HID v1.10 Keyboard [ClockworkPI uConsole] on usb-fe980000.usb-1.1/input0
[ 8.608379] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 8.608647] bcmgenet fd580000.ethernet eth0: Link is Down
[ 8.626813] cdc_acm 1-1.1:1.1: ttyACM0: USB ACM device
[ 8.628483] usbcore: registered new interface driver cdc_acm
[ 8.628495] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 8.662207] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 9.189336] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 10.613594] vc4_hdmi fef00700.hdmi: ASoC: error at snd_soc_dai_startup on fef00700.hdmi: -19
[ 10.614289] vc4_hdmi fef00700.hdmi: ASoC: error at snd_soc_dai_startup on fef00700.hdmi: -19
[ 10.614954] vc4_hdmi fef00700.hdmi: ASoC: error at snd_soc_dai_startup on fef00700.hdmi: -19
[ 10.622998] vc4_hdmi fef00700.hdmi: ASoC: error at snd_soc_dai_startup on fef00700.hdmi: -19
[ 10.623271] vc4_hdmi fef00700.hdmi: ASoC: error at snd_soc_dai_startup on fef00700.hdmi: -19
[ 10.623585] vc4_hdmi fef00700.hdmi: ASoC: error at snd_soc_dai_startup on fef00700.hdmi: -19
[ 10.757587] vc4_hdmi fef05700.hdmi: ASoC: error at snd_soc_dai_startup on fef05700.hdmi: -19
[ 10.758161] vc4_hdmi fef05700.hdmi: ASoC: error at snd_soc_dai_startup on fef05700.hdmi: -19
[ 10.758675] vc4_hdmi fef05700.hdmi: ASoC: error at snd_soc_dai_startup on fef05700.hdmi: -19
[ 10.766237] vc4_hdmi fef05700.hdmi: ASoC: error at snd_soc_dai_startup on fef05700.hdmi: -19
[ 10.766633] vc4_hdmi fef05700.hdmi: ASoC: error at snd_soc_dai_startup on fef05700.hdmi: -19
[ 10.766855] vc4_hdmi fef05700.hdmi: ASoC: error at snd_soc_dai_startup on fef05700.hdmi: -19
[ 12.738619] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 14.520305] Bluetooth: Core ver 2.22
[ 14.520386] NET: Registered protocol family 31
[ 14.520391] Bluetooth: HCI device and connection manager initialized
[ 14.520407] Bluetooth: HCI socket layer initialized
[ 14.520417] Bluetooth: L2CAP socket layer initialized
[ 14.520432] Bluetooth: SCO socket layer initialized
[ 14.527795] Bluetooth: HCI UART driver ver 2.3
[ 14.527809] Bluetooth: HCI UART protocol H4 registered
[ 14.527883] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 14.528065] Bluetooth: HCI UART protocol Broadcom registered
[ 14.725892] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 14.725904] Bluetooth: BNEP filters: protocol multicast
[ 14.725920] Bluetooth: BNEP socket layer initialized
[ 14.738813] NET: Registered protocol family 38
[ 14.755424] cryptd: max_cpu_qlen set to 1000
[ 18.589934] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 86.535309] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 89.928649] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 95.699254] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 190.885584] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 227.850523] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 233.645421] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
cpi@uConsole:~ $
cpi@uConsole:~ $ sudo dmesg | tail
[ 1552.613902] v3d fec00000.v3d: MMU error from client CLE (4) at 0x8ac1000, pte invalid
cpi@uConsole:~ $ sudo systemctl restart ModemManager
cpi@uConsole:~ $ sudo mmcli -S
successfully requested to scan devices
cpi@uConsole:~ $ lsusb
Bus 001 Device 004: ID 1eaf:0024 Leaflabs uConsole
Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
cpi@uConsole:~ $
…I’m not sure if you’re familiar with what’s called a “pastebin”. Do use that next time instead of flooding the conversation with the actual logs.
Anyway, I’m not much of an expert with looking into logs. But I’m not seeing the 4G module registered by the system. You may have to consider reporting to Customer Service for a defective module. Explain the situation before requesting for a replacement under warranty.
Thanks for the tip, and for your help.
Hope it’s nothing but a defective product and will get a replacement for this one
