Accessing the GPS on the expansion card
So, it looks like the expansion card has GPS. Does anyone know how to access it?
Do you need to have a SIM card for it to work? I’d read that GPS was separate from cell service and didn’t need an internet connection on phones—so I’m guessing that it might be accessible without a SIM card.
I saw on one of the pages it says it needs a GPS antenna—but I haven’t found any specifications on what kind of antenna it needs.
Yes, you can access the GPS.
For antenna, you could use a standard GNSS antenna(L1 freq) with builtin LNA. According to the schematics, the antenna socket is powered, so LNA will work. I’ve tested one on my device.
For software, you need to use Modem Manager(MM) to enable the GNSS function. Due to an implementation issue of MM, the GNSS function cannot work without an actual sim card inserted.
Then you have two options: either use gpsd or use MM+dbus. gpsd need full control over GNSS serial port(ttyUSB1 if I’m right), so the command line option for enabling the GNSS function is different.
For gpsd: mmcli -m any --location-enable-gps-unmanaged
For MM+dbus: mmcli -m any --location-enable-gps-nmea --location-enable-gps-raw
As to the configurations for gpsd, please refer to it’s manual.
Some progress—maybe?
This page seems to imply that it should be possible: Techship - FAQ - Basic GNSS/GPS usage guide for SIMcom SIM7100, SIM7500, SIM7600 series cellular modules
I was able to do the following (without a SIM card):
  1. Install minicom: sudo apt install minicom
  2. Turn on the expansion card: uconsole-4g enable
  3. Connect minicom to the modem: minicom -D /dev/ttyUSB3
Then I could send AT commands to the modem. For example, I sent the following:
AT → OK
AT+CVAUXS=0 → OK
AT+CGPS=1,1 → OK
AT+CGPSINFO → ,
So, something’s not quite working. The last command should have been the current GPS location.
However, cat /dev/ttyUSB1 does return data. I have no idea how to use it yet…but it seems like a step in the right direction. Turning GPS off in minicom stopped the data, as expected.
Has anyone found a small compatible antenna with LNA that will fit near the top of the uConsole?
There are now instructions on how to use the GPS on the module but no recommendation of antennas. At least what they look like and specs to search for would be useful.
Have my antenna installed, run the following command and never get an OK confirmation.
echo -en “AT+CGPS=1\r\n” | sudo socat - /dev/ttyUSB3,crnl
Anyone else have this working yet?
Well, rebooted , re-enabled the modem, then re-ran the command and now I get
“Error”
I tried this as well, minicom tells me the port is busy.
I don’t believe I have anything else attached to the port.
Use this one from https://www.aliexpress.com/item/1005005997975660.html
28dBi High Gain GPS Active Antenna BD Built-in Ceramic Antenna Dual Mode GNSS IPEX1 Connector
I got the 20mm x 6.5mm x 6.0mm, 10cm wire length one.
So I tried the instructions and still cannot GPS to work. When I enable the modem, ModemManager says the card is assigned cdc-wdm0. Is it correct that I should still use /dev/ttyUSB3 in this situation? The GPS functionality should coexist OK with using my cellular modem, correct? FYI, I’m using the GPS antenna from HackerGadgets Lora/SDR expansion card antenna kit.
Hi all
So, after some very generous help from Rex, i have my new uConsole with HackerGadgets expansion board and CM5 lite 8GB working beautifully.
I’m experimenting with GPS as well. PyGPS client from Rex’s installer works fine but the mapping element isn’t really there.
I’ve tried to installl GPSD but whilst it appeared successful xgps isn’t showing a connection. When i try to start it suggests it’s already running but i can’t find with ps -ef|grep gpsd.
is it clashing with another gps client? Does anyone have a script for installing with config and driving NavIT or Googlemaps/
Paul
Hi Paul,
Have you got this to work? I still haven’t been able to get my GPS working properly.
Thanks!
Hi
you can read the output from the device without issues but I haven’t got working with gpsd yet. Rex responded saying he was thinking of redoing his image with gpsd active so I’m waiting patiently for that :smiley:
Paul
I’ve struggled to even be able to read from my GPS. I’ve tried to run through the procedure, but can’t get it to work. Can you outline the steps you did, or point me to where I can find the steps that should work? Thanks!
I think you guys are talking about two different GPS devices on different expansion cards.
The GPS on the 4g expansion card is very different from the third party hackergadgets AIO board that also features a GPS
Oh sorry, yes I’m talking about the GPS in the 4G expansion card. Is that not the one Paul was referring to?
Let me try to help.. (?)
i have GPSD running on my CM4 using gps-share. i have concurrent access setup for gpsd as well as google maps under ubuntu.
on CM4, the device is /dev/ttyS0.
on CM5, i think the device is /dev/ttyAMA0
we need to first make sure that you can get gpsd started manually.
If you already have gpsd installed via apt, go to root, and try run “gpsd /dev/ttyS0”
If that starts, then at least the hardware is detected and good. perhaps you can first give that a try?
can you get that started?
