Apt update fails with NO_PUBKEY error
Hi!
I noticed this yesterday, when I do apt update it fails for one repository that I didn’t add by hand, so I’m guessing it came from my a04 image.
root@clockworkpi-a04:~# apt update
Hit:1 http://ports.ubuntu.com hirsute InRelease
Hit:2 http://ppa.launchpad.net/saiarcot895/chromium-dev/ubuntu hirsute InRelease
Hit:3 http://ports.ubuntu.com hirsute-security InRelease
Hit:4 http://ports.ubuntu.com hirsute-updates InRelease
Hit:5 http://ports.ubuntu.com hirsute-backports InRelease
Get:6 https://raw.githubusercontent.com/clockworkpi/apt/main/debian stable InRelease [2,555 B]
Hit:7 http://armbian.12z.eu/apt hirsute InRelease
Err:6 https://raw.githubusercontent.com/clockworkpi/apt/main/debian stable InRelease
  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 4933060A00E71269
Fetched 2,555 B in 3s (938 B/s)
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
1 package can be upgraded. Run 'apt list --upgradable' to see it.
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://raw.githubusercontent.com/clockworkpi/apt/main/debian stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 4933060A00E71269
W: Failed to fetch https://raw.githubusercontent.com/clockworkpi/apt/main/debian/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 4933060A00E71269
W: Some index files failed to download. They have been ignored, or old ones used instead.
So how and where would I get that key?
I also seem to remember that the repository used to work, but I’m not sure.
It’s in /etc/apt/sources.list.d/clockworkpi.list:
root@clockworkpi-a04:~# cat /etc/apt/sources.list.d/clockworkpi.list
deb https://raw.githubusercontent.com/clockworkpi/apt/main/debian/ stable main
apt-key adv --recv-keys 4933060A00E71269
Does not help and it’s also deprecated and the manpage doesn’t clearly tell me what I’m supposed to use instead. I’m guessing gpg --recv-keys with some arguments, but which?
The pubkey in question seems to be here: https://raw.githubusercontent.com/clockworkpi/apt/main/debian/KEY.gpg
wget -O - https://raw.githubusercontent.com/clockworkpi/apt/main/debian/KEY.gpg | sudo apt-key add -
sudo apt-key del  57B7A98BBEBA8C10CA4458810DD08811478B1249
sudo apt update
Everyone needs to update the keys.
Thanks! That worked! :slight_smile:
For those who can’t solve the problem with packmule43’s solution:
1 Use this rom
2 copy /etc/apt/sources.list to your pc
3 copy apt-key to your pc
4 Use the official v0.5 rom
5 replace the /etc/apt/sources.list with the file in your pc
6 import apt-key
7 sudo apt update
and for chinese:
deb http://mirrors.cloud.tencent.com/debian/ buster main non-free contrib
deb http://mirrors.cloud.tencent.com/debian-security buster/updates main
deb http://mirrors.cloud.tencent.com/debian/ buster-updates main non-free contrib
deb http://mirrors.cloud.tencent.com/debian/ buster-backports main non-free contrib
deb-src http://mirrors.cloud.tencent.com/debian-security buster/updates main
deb-src http://mirrors.cloud.tencent.com/debian/ buster main non-free contrib
deb-src http://mirrors.cloud.tencent.com/debian/ buster-updates main non-free contrib
deb-src http://mirrors.cloud.tencent.com/debian/ buster-backports main non-free contrib
The primary issue is that clockwork_os 0.5 needs to be updated to more modern versions of Debian. This can be temporarily worked around by
using a different LTS repository for debs by modifying sources.list
As well as using freexian, you can use debian-archive…
Even better is to use one of the many, modern community created OS builds mentioned on the forums here. Most, if not all, have fixes for various other things including the battery charging issues of the official OS that may reduce battery life. And all have newer kernels and can be updated properly. The official Clockwork OS is only really useful as a hardware test at this point, and is a poor choice for a daily driver.
