Battery PCB Connector
Anyone knows what type of connector did used for board-to-board connection between main board and battery board?
I want to design new battery board as drop-in replacement of the original, but can’t find this connector.
P.S. Still waiting for my unit, so can’t test existing connectors compatibility/
In the scematic is : CF200-00204-1G1, but I cant find a supplyer.
It is a 4pin connector with 2mm pitch, Blade style connector.
I`m working on a CM5 mainboard, but no succes for now with the battery connector.
Found some noname connector on Ali that looks pretty similar
“1Set Blade Battery Connector 2.0MM Pitch 2 3 4 5 6 7 8 9 10 Pin Plug Socket Gold PCB Solder Header Receptacle”
On LCSC i have found by dimensions:
Mainboard connector C29780049 or this C39833034
Battery board connector I cant find the 90degree version just the straight: C39833032
I’ve got this one, looks good. Male part is through-hole, female part - SMD on 24mm reel.
As I’ve understand, it is generic “battery blade connectors”. Found them flat or rounded (rounded corners), straight or 90 degree, with 2.0mm and 2.5mm spacing.
That part number are the connectors on the Main Board not the Battery board
