Does anyone recognize the type of connectors used for the Arduino connections in the key pad module?
I believe they are JST
Hi.
To be precise I think they are “Micro JST SH” connectors. The size should be 1mm high, commonly used for RC projects. I’ll see if I can measure it with a caliper.
C
If @yong or @hal could confirm this that would be nice. Then I can hookup some debugging to the mainboard.
Yes @hal I feel like the docs repository is missing a BOM
For example https://github.com/NextThingCo/CHIP-Hardware/blob/master/CHIP[v1_0]/CHIP_v1_0_BOM_20151030.pdf
JST ZH.
I bought a few of these for my larger battery.
It fits
I think the battery connector has a different pitch than the other mainboard and keypad connectors. So JST SH might still be valid.
Interesting link
https://www.rcgroups.com/forums/showthread.php?1493712-JST-connector-confusion-the-real-story
I didn’t notice the pitch difference!
I think you are correct on the sizing
@Petrakis, that was a great reference. I used my calipers to measure the pitch and they are indeed 1mm.
There is not much info on the cables so I compiled this spreadhseet.
This is what I gathered from my gameshell and my calipers, could be wrong. Let me know if there is something to be changed.
