@mclbn, That makes sense to me, it is good that you are thinking about those things. I use wpa_supplicant to deal with NetworkManager nonsense and I use the credential variable in fstab to point to a credential file in my encrypted home directory. I had forgotten that I originally started doing those things for this exact reason, and your way deals with log files and mine does not.
FYI the fan seems to be working on the devterm already, without the extra overlays.
—also, here’s a link to my post about the custom case design.
Got the TEAMGROUP PRO+ cards. They work good for install and then after 2 reboots I start getting blank screens sometimes. But tapping the power button twice will still turn it off. So it’s running it’s just the screen isn’t working??
(running 6.6.78 on uConsole CM5 lite wifi)
Try plugging in an HDMI monitor. Sometimes the system will startup fine but the built in LCD doesn’t initialize. You will see the desktop on your HDMI monitor. Alternatively, if the system is not starting, you’ll see error messages on the external monitor.
If the button double tap is working, then you most likely have the desktop manager running, even if you can’t see it.
@Anthony_Bernier_Rome Nice setup !
I have some heatsinks in my drawers at home and I am thinking about putting one on the back of y uconsole, like yours. What kind of adhesive did you use ?
I am a bit worried of buying something that will not stick in place, I mostly use my uconsole on the move while traveling.
I used whatever comes with these.
Hasn’t moved one bit since install
legend!
The screen does still have boot problems I’m trying to work out, it is a lot better then it was though. If you can use the power button to shutdown then the sd is working. Besides the screen the sd card is working as it should? What size did you get?
on Latest kernel, CM5 Lite 8GB, 2025/02/12 Bootloader, Samsung Pro Plus 1TB (UHS-III A2 V30)
failed to open device 'sdcard' (cmd 371a0010 status 1fff0001)
I’m testing in many ways without “sdhci.debug_quirks2=4”.
I just waited for the boot loader to detect(I don’t know if it’s actually a perception or just display) the SDCard by repeating the boot sequence, and it was booted. I tested this for the third time.
+ Hold power key to force shutdown is not work in bootloader.
dmesg log, after boot
dmesg1
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x414fd0b1]
[    0.000000] Linux version 6.6.78-v8-16k+ (rex@clockworkpi) (aarch64-linux-gnu-gcc (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #4 SMP PREEMPT Tue Feb 18 08:49:38 EST 2025
[    0.000000] KASLR enabled
[    0.000000] random: crng init done
[    0.000000] Machine model: Raspberry Pi Compute Module 5 Lite Rev 1.0
[    0.000000] efi: UEFI not found.
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000002000000, size 384 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x0000000002000000..0x0000000019ffffff (393216 KiB) map reusable linux,cma
[    0.000000] OF: reserved mem: 0x0000000000000000..0x000000000007ffff (512 KiB) nomap non-reusable atf@0
[    0.000000] OF: reserved mem: 0x000000003fd16340..0x000000003fd163e0 (0 KiB) nomap non-reusable nvram@0
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] Faking a node at [mem 0x0000000000000000-0x000000003fffffff]
[    0.000000] Faking a node at [mem 0x0000000040000000-0x000000007fffffff]
[    0.000000] Faking a node at [mem 0x0000000080000000-0x00000000bfffffff]
[    0.000000] Faking a node at [mem 0x00000000c0000000-0x00000000ffffffff]
[    0.000000] Faking a node at [mem 0x0000000100000000-0x000000013fffffff]
[    0.000000] Faking a node at [mem 0x0000000140000000-0x000000017fffffff]
[    0.000000] Faking a node at [mem 0x0000000180000000-0x00000001bfffffff]
[    0.000000] Faking a node at [mem 0x00000001c0000000-0x00000001ffffffff]
[    0.000000] NUMA: NODE_DATA [mem 0x3fbfd2c0-0x3fbfffff]
[    0.000000] NUMA: NODE_DATA [mem 0x7fffd2c0-0x7fffffff]
[    0.000000] NUMA: NODE_DATA [mem 0xbfffd2c0-0xbfffffff]
[    0.000000] NUMA: NODE_DATA [mem 0xffffd2c0-0xffffffff]
[    0.000000] NUMA: NODE_DATA [mem 0x13fffd2c0-0x13fffffff]
[    0.000000] NUMA: NODE_DATA [mem 0x17fffd2c0-0x17fffffff]
[    0.000000] NUMA: NODE_DATA [mem 0x1bfffd2c0-0x1bfffffff]
[    0.000000] NUMA: NODE_DATA [mem 0x1ffb852c0-0x1ffb87fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000001ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x000000000007ffff]
[    0.000000]   node   0: [mem 0x0000000000080000-0x000000003fbfffff]
[    0.000000]   node   1: [mem 0x0000000040000000-0x000000007fffffff]
[    0.000000]   node   2: [mem 0x0000000080000000-0x00000000bfffffff]
[    0.000000]   node   3: [mem 0x00000000c0000000-0x00000000ffffffff]
[    0.000000]   node   4: [mem 0x0000000100000000-0x000000013fffffff]
[    0.000000]   node   5: [mem 0x0000000140000000-0x000000017fffffff]
[    0.000000]   node   6: [mem 0x0000000180000000-0x00000001bfffffff]
[    0.000000]   node   7: [mem 0x00000001c0000000-0x00000001ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000003fbfffff]
[    0.000000] Initmem setup node 1 [mem 0x0000000040000000-0x000000007fffffff]
[    0.000000] Initmem setup node 2 [mem 0x0000000080000000-0x00000000bfffffff]
[    0.000000] Initmem setup node 3 [mem 0x00000000c0000000-0x00000000ffffffff]
[    0.000000] Initmem setup node 4 [mem 0x0000000100000000-0x000000013fffffff]
[    0.000000] Initmem setup node 5 [mem 0x0000000140000000-0x000000017fffffff]
[    0.000000] Initmem setup node 6 [mem 0x0000000180000000-0x00000001bfffffff]
[    0.000000] Initmem setup node 7 [mem 0x00000001c0000000-0x00000001ffffffff]
[    0.000000] On node 1, zone DMA: 256 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 14 pages/cpu s184232 r8192 d36952 u229376
[    0.000000] pcpu-alloc: s184232 r8192 d36952 u229376 alloc=14*16384
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: Hardware dirty bit management
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: SSBS not fully self-synchronizing
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:D8:B7:A3 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=418650f9-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash usbhid.mousepoll=1 fbcon=rotate:1 psi=1 cfg80211.ieee80211_regdom=KR
[    0.000000] cgroup: Disabling memory control group subsystem
[    0.000000] mempolicy: NUMA default policy overridden to 'interleave:0-7'
[    0.000000] Unknown kernel command line parameters "splash", will be passed to user space.
[    0.000000] Fallback order for Node 0: 0 1 2 3 4 5 6 7
[    0.000000] Fallback order for Node 1: 1 2 3 4 5 6 7 0
[    0.000000] Fallback order for Node 2: 2 3 4 5 6 7 0 1
[    0.000000] Fallback order for Node 3: 3 4 5 6 7 0 1 2
[    0.000000] Fallback order for Node 4: 4 5 6 7 0 1 2 3
[    0.000000] Fallback order for Node 5: 5 6 7 0 1 2 3 4
[    0.000000] Fallback order for Node 6: 6 7 0 1 2 3 4 5
[    0.000000] Fallback order for Node 7: 7 0 1 2 3 4 5 6
[    0.000000] Built 8 zonelists, mobility grouping on.  Total pages: 521985
[    0.000000] Policy zone: Normal
[    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[    0.000000] software IO TLB: area num 4.
[    0.000000] software IO TLB: mapped [mem 0x00000000fbffc000-0x00000000ffffc000] (64MB)
[    0.000000] Memory: 7859536K/8384512K available (13376K kernel code, 2200K rwdata, 4352K rodata, 5056K init, 1216K bss, 131760K reserved, 393216K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=8
[    0.000000] ftrace: allocating 43252 entries in 43 pages
[    0.000000] ftrace: allocated 43 pages with 4 groups
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[    0.000000] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[    0.000134] Console: colour dummy device 80x25
[    0.000138] printk: console [tty1] enabled
[    0.000208] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
[    0.000212] pid_max: default: 32768 minimum: 301
[    0.000303] LSM: initializing lsm=capability,integrity
[    0.001768] Dentry cache hash table entries: 1048576 (order: 9, 8388608 bytes, vmalloc)
[    0.002499] Inode-cache hash table entries: 524288 (order: 8, 4194304 bytes, vmalloc)
[    0.002537] Mount-cache hash table entries: 16384 (order: 3, 131072 bytes, vmalloc)
[    0.002557] Mountpoint-cache hash table entries: 16384 (order: 3, 131072 bytes, vmalloc)
[    0.003175] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.003194] RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.003209] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.003257] rcu: Hierarchical SRCU implementation.
[    0.003259] rcu: 	Max phase no-delay instances is 1000.
[    0.003700] EFI services will not be available.
[    0.003759] smp: Bringing up secondary CPUs ...
[    0.003908] Detected PIPT I-cache on CPU1
[    0.003944] CPU1: Booted secondary processor 0x0000000100 [0x414fd0b1]
[    0.004126] Detected PIPT I-cache on CPU2
[    0.004150] CPU2: Booted secondary processor 0x0000000200 [0x414fd0b1]
[    0.004272] Detected PIPT I-cache on CPU3
[    0.004292] CPU3: Booted secondary processor 0x0000000300 [0x414fd0b1]
[    0.004316] smp: Brought up 8 nodes, 4 CPUs
[    0.004319] SMP: Total of 4 processors activated.
[    0.004321] CPU features: detected: 32-bit EL0 Support
[    0.004323] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.004324] CPU features: detected: Common not Private translations
[    0.004325] CPU features: detected: CRC32 instructions
[    0.004328] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.004329] CPU features: detected: LSE atomic instructions
[    0.004330] CPU features: detected: Privileged Access Never
[    0.004331] CPU features: detected: RAS Extension Support
[    0.004334] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.004359] CPU: All CPU(s) started at EL2
[    0.004361] alternatives: applying system-wide alternatives
[    0.005999] devtmpfs: initialized
[    0.007969] Enabled cp15_barrier support
[    0.007973] Enabled setend support
[    0.008020] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.008025] futex hash table entries: 1024 (order: 2, 65536 bytes, vmalloc)
[    0.008877] pinctrl core: initialized pinctrl subsystem
[    0.009030] DMI not present or invalid.
[    0.009202] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.009707] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.009739] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.009771] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.009801] audit: initializing netlink subsys (disabled)
[    0.009853] audit: type=2000 audit(0.008:1): state=initialized audit_enabled=0 res=1
[    0.009953] thermal_sys: Registered thermal governor 'step_wise'
[    0.009964] cpuidle: using governor menu
[    0.010029] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.010050] ASID allocator initialised with 32768 entries
[    0.010287] Serial: AMBA PL011 UART driver
[    0.010972] bcm2835-mbox 107c013880.mailbox: mailbox enabled
[    0.011214] 107d001000.serial: ttyAMA10 at MMIO 0x107d001000 (irq = 15, base_baud = 0) is a PL011 rev3
[    0.011223] printk: console [ttyAMA10] enabled
[    0.016008] raspberrypi-firmware soc:firmware: Attached to firmware from 2025-02-12T10:51:52, variant start_cd
[    0.020011] raspberrypi-firmware soc:firmware: Firmware hash is f788aab600000000000000000000000000000000
[    0.024882] /axi/pcie@120000/rp1: Fixed dependency cycle(s) with /axi/pcie@120000/rp1
[    0.024912] /axi/pcie@120000/rp1/dsi@128000: Fixed dependency cycle(s) with /axi/pcie@120000/rp1/dsi@128000/panel@0
[    0.024919] /axi/pcie@120000/rp1/dsi@128000/panel@0: Fixed dependency cycle(s) with /axi/pcie@120000/rp1/dsi@128000
[    0.024967] /axi/interrupt-controller@7fff9000: Fixed dependency cycle(s) with /axi/interrupt-controller@7fff9000
[    0.025137] /axi/pcie@120000/rp1: Fixed dependency cycle(s) with /axi/pcie@120000/rp1
[    0.025168] /axi/pcie@120000/rp1/dsi@128000: Fixed dependency cycle(s) with /axi/pcie@120000/rp1/dsi@128000/panel@0
[    0.025176] /axi/pcie@120000/rp1/dsi@128000/panel@0: Fixed dependency cycle(s) with /axi/pcie@120000/rp1/dsi@128000
[    0.025753] Modules: 2G module region forced by RANDOMIZE_MODULE_REGION_FULL
[    0.025755] Modules: 0 pages in range for non-PLT usage
[    0.025756] Modules: 129412 pages in range for PLT usage
[    0.028834] bcm2835-dma 1000010000.dma: DMA legacy API manager, dmachans=0x1
[    0.029081] iommu: Default domain type: Translated
[    0.029083] iommu: DMA domain TLB invalidation policy: strict mode
[    0.029153] SCSI subsystem initialized
[    0.029179] usbcore: registered new interface driver usbfs
[    0.029184] usbcore: registered new interface driver hub
[    0.029191] usbcore: registered new device driver usb
[    0.029248] pps_core: LinuxPPS API ver. 1 registered
[    0.029250] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.029252] PTP clock support registered
[    0.029636] vgaarb: loaded
[    0.029721] clocksource: Switched to clocksource arch_sys_counter
[    0.207109] VFS: Disk quotas dquot_6.6.0
[    0.207117] VFS: Dquot-cache hash table entries: 2048 (order 0, 16384 bytes)
[    0.207144] FS-Cache: Loaded
[    0.207183] CacheFiles: Loaded
[    0.208049] NET: Registered PF_INET protocol family
[    0.208196] IP idents hash table entries: 131072 (order: 6, 1048576 bytes, vmalloc)
[    0.209705] tcp_listen_portaddr_hash hash table entries: 4096 (order: 2, 65536 bytes, vmalloc)
[    0.209752] Table-perturb hash table entries: 65536 (order: 4, 262144 bytes, vmalloc)
[    0.209762] TCP established hash table entries: 65536 (order: 5, 524288 bytes, vmalloc)
[    0.209940] TCP bind hash table entries: 65536 (order: 7, 2097152 bytes, vmalloc)
[    0.210610] TCP: Hash tables configured (established 65536 bind 65536)
[    0.210716] MPTCP token hash table entries: 8192 (order: 3, 196608 bytes, vmalloc)
[    0.210751] UDP hash table entries: 4096 (order: 3, 131072 bytes, vmalloc)
[    0.210816] UDP-Lite hash table entries: 4096 (order: 3, 131072 bytes, vmalloc)
[    0.210913] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.211015] RPC: Registered named UNIX socket transport module.
[    0.211017] RPC: Registered udp transport module.
[    0.211018] RPC: Registered tcp transport module.
[    0.211019] RPC: Registered tcp-with-tls transport module.
[    0.211020] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.211024] PCI: CLS 0 bytes, default 64
[    0.211148] kvm [1]: IPA Size Limit: 40 bits
[    0.211156] kvm [1]: GICV region size/alignment is unsafe, using trapping (reduced performance)
[    0.211173] kvm [1]: vgic interrupt IRQ9
[    0.211183] kvm [1]: VHE mode initialized successfully
[    0.211481] Initialise system trusted keyrings
[    0.211595] workingset: timestamp_bits=42 max_order=19 bucket_order=0
[    0.211608] zbud: loaded
[    0.211810] NFS: Registering the id_resolver key type
[    0.211815] Key type id_resolver registered
[    0.211816] Key type id_legacy registered
[    0.211826] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.211828] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.211853] F2FS not supported on PAGE_SIZE(16384) != 4096
[    0.211892] Key type asymmetric registered
[    0.211893] Asymmetric key parser 'x509' registered
[    0.211905] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.211925] io scheduler mq-deadline registered
[    0.211927] io scheduler kyber registered
[    0.211945] io scheduler bfq registered
[    0.212116] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7c502000, parent irq: 26)
[    0.212159] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d503000, parent irq: 27)
[    0.212189] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d508380, parent irq: 28)
[    0.212215] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d508400, parent irq: 29)
[    0.212249] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7d510600, parent irq: 30)
[    0.212278] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d517b00, parent irq: 31)
[    0.241333] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[    0.241587] 107d50c000.serial: ttyS0 at MMIO 0x107d50c000 (irq = 33, base_baud = 6000000) is a Broadcom BCM7271 UART
[    0.241620] serial serial0: tty port ttyS0 registered
[    0.241836] iproc-rng200 107d208000.rng: hwrng registered
[    0.241870] vc-mem: phys_addr:0x00000000 mem_base=0x3fc00000 mem_size:0x40000000(1024 MiB)
[    0.242009] bcm2712-iommu-cache 1000005b00.iommuc: bcm2712_iommu_cache_probe
[    0.243260] brd: module loaded
[    0.244130] loop: module loaded
[    0.244216] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[    0.244306] Loading iSCSI transport class v2.0-870.
[    0.244882] usbcore: registered new device driver r8152-cfgselector
[    0.244887] usbcore: registered new interface driver r8152
[    0.244892] usbcore: registered new interface driver lan78xx
[    0.244896] usbcore: registered new interface driver smsc95xx
[    0.244897] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    0.244911] dwc_otg: FIQ enabled
[    0.244912] dwc_otg: NAK holdoff enabled
[    0.244913] dwc_otg: FIQ split-transaction FSM enabled
[    0.244915] Module dwc_common_port init
[    0.244992] usbcore: registered new interface driver uas
[    0.244997] usbcore: registered new interface driver usb-storage
[    0.245061] mousedev: PS/2 mouse device common for all mice
[    0.252496] rpi-rtc soc:rpi_rtc: registered as rtc0
[    0.253867] rpi-rtc soc:rpi_rtc: setting system clock to 1970-01-01T00:11:03 UTC (663)
[    0.254096] bcm2835-wdt bcm2835-wdt: Poweroff handler already present!
[    0.254098] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    0.256240] sdhci: Secure Digital Host Controller Interface driver
[    0.256242] sdhci: Copyright(c) Pierre Ossman
[    0.256269] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.256414] ledtrig-cpu: registered to indicate activity on CPUs
[    0.256448] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.256456] hid: raw HID events driver (C) Jiri Kosina
[    0.256473] usbcore: registered new interface driver usbhid
[    0.256474] usbhid: USB HID core driver
[    0.256698] hw perfevents: enabled with armv8_cortex_a76 PMU driver, 7 counters available
[    0.256940] NET: Registered PF_PACKET protocol family
[    0.256961] Key type dns_resolver registered
[    0.260277] registered taskstats version 1
[    0.260344] Loading compiled-in X.509 certificates
[    0.261752] Key type .fscrypt registered
[    0.261754] Key type fscrypt-provisioning registered
[    0.262181] brcm-pcie 1000120000.pcie: host bridge /axi/pcie@120000 ranges:
[    0.262185] brcm-pcie 1000120000.pcie:   No bus range found for /axi/pcie@120000, using [bus 00-ff]
[    0.262193] brcm-pcie 1000120000.pcie:      MEM 0x1f00000000..0x1ffffffffb -> 0x0000000000
[    0.262197] brcm-pcie 1000120000.pcie:      MEM 0x1c00000000..0x1effffffff -> 0x0400000000
[    0.262203] brcm-pcie 1000120000.pcie:   IB MEM 0x1f00000000..0x1f003fffff -> 0x0000000000
[    0.262206] brcm-pcie 1000120000.pcie:   IB MEM 0x0000000000..0x0fffffffff -> 0x1000000000
[    0.263468] brcm-pcie 1000120000.pcie: Forcing gen 2
[    0.263596] brcm-pcie 1000120000.pcie: PCI host bridge to bus 0000:00
[    0.263598] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.263600] pci_bus 0000:00: root bus resource [mem 0x1f00000000-0x1ffffffffb] (bus address [0x00000000-0xfffffffb])
[    0.263602] pci_bus 0000:00: root bus resource [mem 0x1c00000000-0x1effffffff pref] (bus address [0x400000000-0x6ffffffff])
[    0.263613] pci 0000:00:00.0: [14e4:2712] type 01 class 0x060400
[    0.263633] pci 0000:00:00.0: PME# supported from D0 D3hot
[    0.264285] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    0.369723] brcm-pcie 1000120000.pcie: link up, 5.0 GT/s PCIe x4 (!SSC)
[    0.369742] pci 0000:01:00.0: [1de4:0001] type 00 class 0x020000
[    0.369755] pci 0000:01:00.0: reg 0x10: [mem 0xffffc000-0xffffffff]
[    0.369762] pci 0000:01:00.0: reg 0x14: [mem 0xffc00000-0xffffffff]
[    0.369767] pci 0000:01:00.0: reg 0x18: [mem 0xffff0000-0xffffffff]
[    0.369830] pci 0000:01:00.0: supports D1
[    0.369832] pci 0000:01:00.0: PME# supported from D0 D1 D3hot D3cold
[    0.381729] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    0.381737] pci 0000:00:00.0: BAR 8: assigned [mem 0x1f00000000-0x1f005fffff]
[    0.381739] pci 0000:01:00.0: BAR 1: assigned [mem 0x1f00000000-0x1f003fffff]
[    0.381743] pci 0000:01:00.0: BAR 2: assigned [mem 0x1f00400000-0x1f0040ffff]
[    0.381747] pci 0000:01:00.0: BAR 0: assigned [mem 0x1f00410000-0x1f00413fff]
[    0.381751] pci 0000:00:00.0: PCI bridge to [bus 01]
[    0.381753] pci 0000:00:00.0:   bridge window [mem 0x1f00000000-0x1f005fffff]
[    0.381757] pci 0000:00:00.0: Max Payload Size set to  256/ 512 (was  128), Max Read Rq  512
[    0.381764] pci 0000:01:00.0: Max Payload Size set to  256/ 256 (was  128), Max Read Rq  512
[    0.381819] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[    0.381844] pcieport 0000:00:00.0: PME: Signaling with IRQ 38
[    0.381893] pcieport 0000:00:00.0: AER: enabled with IRQ 38
[    0.381946] rp1 0000:01:00.0: bar0 len 0x4000, start 0x1f00410000, end 0x1f00413fff, flags, 0x40200
[    0.381949] rp1 0000:01:00.0: bar1 len 0x400000, start 0x1f00000000, end 0x1f003fffff, flags, 0x40200
[    0.381956] rp1 0000:01:00.0: enabling device (0000 -> 0002)
[    0.382563] rp1 0000:01:00.0: chip_id 0x20001927
[    0.386564] genirq: irq_chip rp1_irq_chip did not update eff. affinity mask of irq 100
[    0.387344] dw_axi_dmac_platform 1f00188000.dma: DesignWare AXI DMA Controller, 8 channels
[    0.387674] /axi/pcie@120000/rp1/dsi@128000: Fixed dependency cycle(s) with /axi/pcie@120000/rp1/dsi@128000/panel@0
[    0.388346] bcm2712-iommu 1000005100.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
[    0.388734] platform 1000800000.codec: bcm2712_iommu_probe_device: MMU 1000005100.iommu
[    0.388738] platform 1000800000.codec: bcm2712_iommu_device_group: MMU 1000005100.iommu
[    0.388741] platform 1000800000.codec: Adding to iommu group 0
[    0.388748] platform 1000880000.pisp_be: bcm2712_iommu_probe_device: MMU 1000005100.iommu
[    0.388751] platform 1000880000.pisp_be: bcm2712_iommu_device_group: MMU 1000005100.iommu
[    0.388754] platform 1000880000.pisp_be: Adding to iommu group 0
[    0.388772] platform 1000800000.codec: bcm2712_iommu_attach_dev: MMU 1000005100.iommu
[    0.388773] platform 1000880000.pisp_be: bcm2712_iommu_attach_dev: MMU 1000005100.iommu
[    0.388776] bcm2712-iommu 1000005100.iommu: bcm2712_iommu_probe: Success
[    0.389187] bcm2712-iommu 1000005200.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
[    0.389556] platform axi:gpu: bcm2712_iommu_probe_device: MMU 1000005200.iommu
[    0.389558] platform axi:gpu: bcm2712_iommu_device_group: MMU 1000005200.iommu
[    0.389561] platform axi:gpu: Adding to iommu group 1
[    0.389575] platform axi:gpu: bcm2712_iommu_attach_dev: MMU 1000005200.iommu
[    0.389577] bcm2712-iommu 1000005200.iommu: bcm2712_iommu_probe: Success
[    0.389968] bcm2712-iommu 1000005280.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
[    0.390340] platform 1f00130000.dsi: bcm2712_iommu_probe_device: MMU 1000005280.iommu
[    0.390343] platform 1f00130000.dsi: bcm2712_iommu_device_group: MMU 1000005280.iommu
[    0.390346] platform 1f00130000.dsi: Adding to iommu group 2
[    0.390348] platform 1f00130000.dsi: bcm2712_iommu_attach_dev: MMU 1000005280.iommu
[    0.390350] bcm2712-iommu 1000005280.iommu: bcm2712_iommu_probe: Success
[    0.390547] mmc0: CQHCI version 5.10
[    0.390919] mmc1: CQHCI version 5.10
[    0.391134] of_cfs_init
[    0.391159] of_cfs_init: OK
[    0.391215] clk: Disabling unused clocks
[    0.426246] mmc0: SDHCI controller on 1000fff000.mmc [1000fff000.mmc] using ADMA 64-bit
[    0.547969] mmc0: new ultra high speed SDR104 SDXC card at address 0001
[    0.548125] mmcblk0: mmc0:0001 FG8Y7 955 GiB
[    0.548935]  mmcblk0: p1 p2
[    0.548998] mmcblk0: mmc0:0001 FG8Y7 955 GiB
[    0.580255] mmc1: SDHCI controller on 1001100000.mmc [1001100000.mmc] using ADMA 64-bit
dmesg2
[    0.593312] EXT4-fs (mmcblk0p2): mounted filesystem e738ada3-da98-489b-b98d-6d97fd85ea62 ro with ordered data mode. Quota mode: none.
[    0.593332] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    0.593602] devtmpfs: mounted
[    0.596167] Freeing unused kernel memory: 5056K
[    0.596213] Run /sbin/init as init process
[    0.596215]   with arguments:
[    0.596215]     /sbin/init
[    0.596216]     splash
[    0.596218]   with environment:
[    0.596219]     HOME=/
[    0.596219]     TERM=linux
[    0.610129] mmc1: new ultra high speed DDR50 SDIO card at address 0001
[    0.750284] systemd[1]: System time before build time, advancing clock.
[    0.795247] NET: Registered PF_INET6 protocol family
[    0.795487] Segment Routing with IPv6
[    0.795492] In-situ OAM (IOAM) with IPv6
[    0.815356] systemd[1]: systemd 252.33-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    0.815369] systemd[1]: Detected architecture arm64.
[    0.819076] systemd[1]: Hostname set to <uconsole>.
[    0.846738] systemd[1]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[    1.197801] uart-pl011 107d001000.serial: no DMA platform data
[    1.339635] systemd[1]: Queued start job for default target graphical.target.
[    1.358466] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[    1.358788] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[    1.359051] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[    1.359301] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
[    1.359470] systemd[1]: Created slice user.slice - User and Session Slice.
[    1.359525] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[    1.359669] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[    1.359687] systemd[1]: Expecting device dev-disk-by\x2dpartuuid-418650f9\x2d01.device - /dev/disk/by-partuuid/418650f9-01...
[    1.359696] systemd[1]: Expecting device dev-ttyAMA10.device - /dev/ttyAMA10...
[    1.359722] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[    1.359747] systemd[1]: Reached target nss-user-lookup.target - User and Group Name Lookups.
[    1.359768] systemd[1]: Reached target slices.target - Slice Units.
[    1.359786] systemd[1]: Reached target swap.target - Swaps.
[    1.359807] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[    1.359911] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
[    1.359954] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[    1.360153] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
[    1.360237] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[    1.360326] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[    1.360686] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[    1.360754] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[    1.360868] systemd[1]: dev-hugepages.mount - Huge Pages File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
[    1.361544] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[    1.362393] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[    1.363197] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[    1.363357] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
[    1.365010] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
[    1.366926] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
[    1.367979] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[    1.369336] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
[    1.370606] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
[    1.372034] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[    1.373556] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[    1.374879] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
[    1.376268] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
[    1.378365] systemd[1]: Starting systemd-fsck-root.service - File System Check on Root Device...
[    1.380358] systemd[1]: Starting systemd-journald.service - Journal Service...
[    1.386305] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[    1.387399] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
[    1.388096] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[    1.389523] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[    1.389643] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[    1.389708] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[    1.390041] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
[    1.390374] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
[    1.390585] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[    1.390685] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
[    1.390880] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[    1.390959] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
[    1.391161] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[    1.391253] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[    1.391449] systemd[1]: modprobe@loop.service: Deactivated successfully.
[    1.391549] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
[    1.392624] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
[    1.393700] systemd[1]: Started systemd-fsckd.service - File System Check Daemon to report status.
[    1.394015] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
[    1.394701] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
[    1.401441] fuse: init (API version 7.39)
[    1.402639] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[    1.405798] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
[    1.406253] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
[    1.407427] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
[    1.409083] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
[    1.410719] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
[    1.422897] systemd[1]: modprobe@drm.service: Deactivated successfully.
[    1.423016] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
[    1.426188] systemd[1]: Started systemd-journald.service - Journal Service.
[    1.775013] EXT4-fs (mmcblk0p2): re-mounted e738ada3-da98-489b-b98d-6d97fd85ea62 r/w. Quota mode: none.
[    1.801441] systemd-journald[149]: Received client request to flush runtime journal.
[    1.810390] systemd-journald[149]: File /var/log/journal/ccd96561469d42debc085d5d61227028/system.journal corrupted or uncleanly shut down, renaming and replacing.
[    2.140970] rpi-gpiomem 107d508500.gpiomem: window base 0x107d508500 size 0x00000040
[    2.141098] rpi-gpiomem 107d508500.gpiomem: initialised 1 regions as /dev/gpiomem1
[    2.142583] rpi-gpiomem 107d517c00.gpiomem: window base 0x107d517c00 size 0x00000040
[    2.142825] rpi-gpiomem 107d517c00.gpiomem: initialised 1 regions as /dev/gpiomem2
[    2.142864] rpi-gpiomem 107d504100.gpiomem: window base 0x107d504100 size 0x00000020
[    2.142903] rpi-gpiomem 107d504100.gpiomem: initialised 1 regions as /dev/gpiomem3
[    2.142926] rpi-gpiomem 107d510700.gpiomem: window base 0x107d510700 size 0x00000020
[    2.142952] rpi-gpiomem 107d510700.gpiomem: initialised 1 regions as /dev/gpiomem4
[    2.143023] rpi-gpiomem 1f000d0000.gpiomem: window base 0x1f000d0000 size 0x00030000
[    2.143110] rpi-gpiomem 1f000d0000.gpiomem: initialised 1 regions as /dev/gpiomem0
[    2.156610] dwc2 1000480000.usb: supply vusb_d not found, using dummy regulator
[    2.156661] dwc2 1000480000.usb: supply vusb_a not found, using dummy regulator
[    2.164116] axp20x-i2c 0-0034: AXP20x variant AXP221 found
[    2.167836] mc: Linux media interface: v0.10
[    2.168254] rp1-firmware rp1_firmware: RP1 Firmware version eb39cfd516f8c90628aa9d91f52370aade5d0a55
[    2.177537] axp20x-gpio: Failed to locate of_node [id: -1]
[    2.197068] drm-rp1-dsi 1f00130000.dsi: bcm2712_iommu_of_xlate: MMU 1000005280.iommu
[    2.206483] videodev: Linux video capture interface: v2.00
[    2.207132] input: axp20x-pek as /devices/platform/axi/1000120000.pcie/1f00070000.i2c/i2c-0/0-0034/axp221-pek/input/input0
[    2.207499] brcmstb-i2c 107d508200.i2c:  @97500hz registered in interrupt mode
[    2.207739] input: pwr_button as /devices/platform/pwr_button/input/input1
[    2.209257] dwc2 1000480000.usb: DWC OTG Controller
[    2.209265] dwc2 1000480000.usb: new USB bus registered, assigned bus number 1
[    2.209270] dwc2 1000480000.usb: irq 192, io mem 0x1000480000
[    2.209408] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[    2.209411] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.209413] usb usb1: Product: DWC OTG Controller
[    2.209415] usb usb1: Manufacturer: Linux 6.6.78-v8-16k+ dwc2_hsotg
[    2.209417] usb usb1: SerialNumber: 1000480000.usb
[    2.210465] brcmstb-i2c 107d508280.i2c:  @97500hz registered in interrupt mode
[    2.210529] hub 1-0:1.0: USB hub found
[    2.210547] hub 1-0:1.0: 1 port detected
[    2.211508] rp1-pio 1f00178000.pio: Created instance as pio0
[    2.211682] axp22x-adc: Failed to locate of_node [id: -1]
[    2.212335] axp20x-usb-power-supply: Failed to locate of_node [id: -1]
[    2.212357] axp20x-i2c 0-0034: AXP20X driver loaded
[    2.220805] [drm] Initialized v3d 1.0.0 20180419 for 1002000000.v3d on minor 1
[    2.246322] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    2.252580] Loaded X.509 cert 'benh@debian.org: 577e021cb980e0e820821ba7b54b4961b8b4fadf'
[    2.252926] Loaded X.509 cert 'romain.perier@gmail.com: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328'
[    2.253164] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    2.253365] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[    2.280374] dldo2: Bringing 700000uV into 3300000-3300000uV
[    2.285859] dldo3: Bringing 700000uV into 3300000-3300000uV
[    2.289682] dldo4: Bringing 700000uV into 3300000-3300000uV
[    2.324144] pispbe 1000880000.pisp_be: bcm2712_iommu_of_xlate: MMU 1000005100.iommu
[    2.330710] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
[    2.332028] brcmfmac: F1 signature read @0x18000000=0x15264345
[    2.334969] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    2.336484] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,5-compute-module.bin failed with error -2
[    2.336530] rpivid 1000800000.codec: bcm2712_iommu_of_xlate: MMU 1000005100.iommu
[    2.336980] pispbe 1000880000.pisp_be: Runtime PM usage count underflow!
[    2.343691] rpivid 1000800000.codec: Device registered as /dev/video19
[    2.370815] usbcore: registered new interface driver brcmfmac
[    2.459606] vc4-drm axi:gpu: bcm2712_iommu_of_xlate: MMU 1000005200.iommu
[    2.461273] Bluetooth: Core ver 2.22
[    2.461299] NET: Registered PF_BLUETOOTH protocol family
[    2.461301] Bluetooth: HCI device and connection manager initialized
[    2.461307] Bluetooth: HCI socket layer initialized
[    2.461309] Bluetooth: L2CAP socket layer initialized
[    2.461312] Bluetooth: SCO socket layer initialized
[    2.485629] vc4-drm axi:gpu: bound 107c580000.hvs (ops vc4_hvs_ops [vc4])
[    2.488564] Bluetooth: HCI UART driver ver 2.3
[    2.488577] Bluetooth: HCI UART protocol H4 registered
[    2.488619] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    2.488786] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator
[    2.488831] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator
[    2.488860] Bluetooth: HCI UART protocol Broadcom registered
[    2.504929] drm-rp1-dsi 1f00130000.dsi: rp1dsi_host_attach: Attach DSI device name=cwu50-cm5 channel=0 lanes=4 format=0 flags=0x7 hs_rate=0 lp_rate=0
[    2.509748] usb 1-1: new high-speed USB device number 2 using dwc2
[    2.510916] Registered IR keymap rc-cec
[    2.514847] rc rc0: vc4-hdmi-0 as /devices/platform/soc/107c701400.hdmi/rc/rc0
[    2.516676] input: vc4-hdmi-0 as /devices/platform/soc/107c701400.hdmi/rc/rc0/input2
[    2.518959] input: vc4-hdmi-0 HDMI Jack as /devices/platform/soc/107c701400.hdmi/sound/card0/input3
[    2.519887] [drm] Initialized drm-rp1-dsi 1.0.0 0 for 1f00130000.dsi on minor 0
[    2.523627] vc4-drm axi:gpu: bound 107c701400.hdmi (ops vc4_hdmi_ops [vc4])
[    2.527890] drm-rp1-dsi 1f00130000.dsi: [drm] rp1dsi: Command time (outvact): 8
[    2.528403] drm-rp1-dsi 1f00130000.dsi: [drm] rp1dsi: Nominal Byte clock 45833333 DPI clock 61111240 (parent rate 200000000)
[    2.530400] panel-cwu50-cm5 1f00130000.dsi.0: CWU50: Resetting panel... (Attempt 1)
[    2.536503] Registered IR keymap rc-cec
[    2.536576] rc rc1: vc4-hdmi-1 as /devices/platform/soc/107c706400.hdmi/rc/rc1
[    2.536624] input: vc4-hdmi-1 as /devices/platform/soc/107c706400.hdmi/rc/rc1/input4
[    2.546791] input: vc4-hdmi-1 HDMI Jack as /devices/platform/soc/107c706400.hdmi/sound/card1/input5
[    2.552819] vc4-drm axi:gpu: bound 107c706400.hdmi (ops vc4_hdmi_ops [vc4])
[    2.552995] vc4-drm axi:gpu: bound 107c500000.mop (ops vc4_txp_ops [vc4])
[    2.553100] vc4-drm axi:gpu: bound 107c501000.moplet (ops vc4_txp_ops [vc4])
[    2.553226] vc4-drm axi:gpu: bound 107c410000.pixelvalve (ops vc4_crtc_ops [vc4])
[    2.553342] vc4-drm axi:gpu: bound 107c411000.pixelvalve (ops vc4_crtc_ops [vc4])
[    2.556492] [drm] Initialized vc4 0.0.0 20140616 for axi:gpu on minor 2
[    2.727037] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.38
[    2.727042] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    2.727044] usb 1-1: Product: USB2.0 Hub
[    2.727441] hub 1-1:1.0: USB hub found
[    2.727673] hub 1-1:1.0: 4 ports detected
[    2.732301] axp20x-ac-power-supply axp20x-ac-power-supply: DMA mask not set
[    2.732398] axp20x-battery-power-supply axp20x-battery-power-supply: DMA mask not set
[    2.735204] brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (err=-2)
[    2.735564] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Aug 29 2023 01:47:08 version 7.45.265 (28bca26 CY) FWID 01-b677b91b
[    2.846551] Bluetooth: hci0: BCM: chip id 107
[    2.846754] Bluetooth: hci0: BCM: features 0x2f
[    2.847936] Bluetooth: hci0: BCM4345C0
[    2.847937] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0000
[    2.849084] Bluetooth: hci0: BCM4345C0 'brcm/BCM4345C0.hcd' Patch
[    2.909733] panel-cwu50-cm5 1f00130000.dsi.0: CWU50: Running initialization sequence...
[    3.225722] panel-cwu50-cm5 1f00130000.dsi.0: CWU50: Attempting to exit sleep mode (try 1/5)...
[    3.225734] panel-cwu50-cm5 1f00130000.dsi.0: CWU50: Successfully exited sleep mode
[    3.534340] Bluetooth: hci0: BCM: features 0x2f
[    3.535662] Bluetooth: hci0: BCM43455 37.4MHz Raspberry Pi 3+-0190
[    3.535664] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0382
[    3.535944] Bluetooth: hci0: BCM: Using default device address (43:45:c0:00:1f:ac)
[    3.549891] panel-cwu50-cm5 1f00130000.dsi.0: CWU50: Panel power mode: 0x18
[    3.549892] panel-cwu50-cm5 1f00130000.dsi.0: CWU50: Panel power mode stable at 0x18
[    3.549894] panel-cwu50-cm5 1f00130000.dsi.0: CWU50: Turning display on...
[    3.709721] panel-cwu50-cm5 1f00130000.dsi.0: CWU50: Enabling backlight...
[    3.777721] panel-cwu50-cm5 1f00130000.dsi.0: CWU50: Panel successfully prepared
[    3.794394] Console: switching to colour frame buffer device 160x45
[    3.812165] drm-rp1-dsi 1f00130000.dsi: [drm] fb0: drm-rp1-dsidrmf frame buffer device
[    3.812443] vc4-drm axi:gpu: [drm] fb1: vc4drmfb frame buffer device
[    3.825733] drm-rp1-dsi 1f00130000.dsi: rp1dsi_bind succeeded
[    4.113743] usb 1-1.1: new full-speed USB device number 3 using dwc2
[    4.214816] usb 1-1.1: New USB device found, idVendor=1eaf, idProduct=0003, bcdDevice= 2.01
[    4.214824] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    4.214826] usb 1-1.1: Product: Maple 003
[    4.214828] usb 1-1.1: Manufacturer: LeafLabs
[    4.214830] usb 1-1.1: SerialNumber: LLM 003
[    4.246451] Adding 204784k swap on /var/swap.  Priority:-2 extents:12 across:3719168k SS
[    4.497696] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    4.497705] Bluetooth: BNEP filters: protocol multicast
[    4.497712] Bluetooth: BNEP socket layer initialized
[    4.500635] Bluetooth: MGMT ver 1.22
[    4.506514] NET: Registered PF_ALG protocol family
[    4.547099] usb 1-1.1: USB disconnect, device number 3
[    4.781750] usb 1-1.1: new full-speed USB device number 4 using dwc2
[    4.883638] usb 1-1.1: New USB device found, idVendor=feed, idProduct=0000, bcdDevice= 1.00
[    4.883646] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    4.883649] usb 1-1.1: Product: uConsole Keyboard
[    4.883650] usb 1-1.1: Manufacturer: Clockwork
[    4.883652] usb 1-1.1: SerialNumber: 54FF6C06787550500738126700000000
[    4.884787] input: Clockwork uConsole Keyboard as /devices/platform/axi/1000480000.usb/usb1/1-1/1-1.1/1-1.1:1.0/0003:FEED:0000.0001/input/input6
[    5.005921] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[    5.057989] hid-generic 0003:FEED:0000.0001: input,hidraw0: USB HID v1.11 Keyboard [Clockwork uConsole Keyboard] on usb-1000480000.usb-1.1/input0
[    5.059278] input: Clockwork uConsole Keyboard Mouse as /devices/platform/axi/1000480000.usb/usb1/1-1/1-1.1/1-1.1:1.1/0003:FEED:0000.0002/input/input7
[    5.059362] input: Clockwork uConsole Keyboard as /devices/platform/axi/1000480000.usb/usb1/1-1/1-1.1/1-1.1:1.1/0003:FEED:0000.0002/input/input8
[    5.059411] input: Clockwork uConsole Keyboard System Control as /devices/platform/axi/1000480000.usb/usb1/1-1/1-1.1/1-1.1:1.1/0003:FEED:0000.0002/input/input9
[    5.119315] input: Clockwork uConsole Keyboard Consumer Control as /devices/platform/axi/1000480000.usb/usb1/1-1/1-1.1/1-1.1:1.1/0003:FEED:0000.0002/input/input10
[    5.119417] input: Clockwork uConsole Keyboard as /devices/platform/axi/1000480000.usb/usb1/1-1/1-1.1/1-1.1:1.1/0003:FEED:0000.0002/input/input11
[    5.230050] hid-generic 0003:FEED:0000.0002: input,hidraw1: USB HID v1.11 Mouse [Clockwork uConsole Keyboard] on usb-1000480000.usb-1.1/input1
[    5.230875] hid-generic 0003:FEED:0000.0003: hiddev96,hidraw2: USB HID v1.11 Device [Clockwork uConsole Keyboard] on usb-1000480000.usb-1.1/input2
[   20.536623] Initializing XFRM netlink socket
[   20.617173] Bluetooth: RFCOMM TTY layer initialized
[   20.617188] Bluetooth: RFCOMM socket layer initialized
[   20.617196] Bluetooth: RFCOMM ver 1.11
[   20.747344] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[   27.154800] rfkill: input handler disabled
[   81.164647] irq 163: nobody cared (try booting with the "irqpoll" option)
[   81.164655] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G         C         6.6.78-v8-16k+ #4
[   81.164658] Hardware name: Raspberry Pi Compute Module 5 Lite Rev 1.0 (DT)
[   81.164660] Call trace:
[   81.164662]  dump_backtrace+0xa0/0x100
[   81.164668]  show_stack+0x20/0x38
[   81.164670]  dump_stack_lvl+0x48/0x60
[   81.164675]  dump_stack+0x18/0x28
[   81.164677]  __report_bad_irq+0x40/0xf0
[   81.164681]  note_interrupt+0x328/0x380
[   81.164684]  handle_irq_event+0xa4/0xc0
[   81.164686]  handle_level_irq+0xc8/0x1b0
[   81.164689]  handle_irq_desc+0x48/0x68
[   81.164691]  generic_handle_irq+0x28/0x40
[   81.164693]  rp1_gpio_irq_handler+0x134/0x200
[   81.164698]  handle_irq_desc+0x48/0x68
[   81.164700]  generic_handle_irq+0x28/0x40
[   81.164701]  rp1_chained_handle_irq+0x7c/0x120
[   81.164705]  handle_irq_desc+0x48/0x68
[   81.164707]  generic_handle_domain_irq+0x24/0x38
[   81.164709]  gic_handle_irq+0x4c/0xd8
[   81.164711]  call_on_irq_stack+0x24/0x58
[   81.164713]  do_interrupt_handler+0x88/0x98
[   81.164716]  el1_interrupt+0x34/0x68
[   81.164719]  el1h_64_irq_handler+0x18/0x28
[   81.164722]  el1h_64_irq+0x64/0x68
[   81.164724]  default_idle_call+0x5c/0x170
[   81.164727]  do_idle+0x208/0x240
[   81.164729]  cpu_startup_entry+0x3c/0x50
[   81.164731]  rest_init+0xf0/0xf8
[   81.164733]  arch_call_rest_init+0x18/0x20
[   81.164738]  start_kernel+0x534/0x698
[   81.164740]  __primary_switched+0xbc/0xd0
[   81.164743] handlers:
[   81.164744] [<00000000645f7006>] irq_default_primary_handler threaded [<000000009848a3b6>] regmap_irq_thread
[   81.164751] Disabling IRQ #163
[  194.014591] drm-rp1-dsi 1f00130000.dsi: [drm] rp1dsi: Command time (outvact): 8
[  194.014966] drm-rp1-dsi 1f00130000.dsi: [drm] rp1dsi: Nominal Byte clock 45833333 DPI clock 61111240 (parent rate 200000000)
[  194.484487] input: Clockwork uConsole Keyboard as /devices/platform/axi/1000480000.usb/usb1/1-1/1-1.1/1-1.1:1.0/0003:FEED:0000.0004/input/input12
[  194.614093] hid-generic 0003:FEED:0000.0004: input,hidraw0: USB HID v1.11 Keyboard [Clockwork uConsole Keyboard] on usb-1000480000.usb-1.1/input0
[  194.615840] input: Clockwork uConsole Keyboard Mouse as /devices/platform/axi/1000480000.usb/usb1/1-1/1-1.1/1-1.1:1.1/0003:FEED:0000.0005/input/input13
[  194.615939] input: Clockwork uConsole Keyboard as /devices/platform/axi/1000480000.usb/usb1/1-1/1-1.1/1-1.1:1.1/0003:FEED:0000.0005/input/input14
[  194.616012] input: Clockwork uConsole Keyboard System Control as /devices/platform/axi/1000480000.usb/usb1/1-1/1-1.1/1-1.1:1.1/0003:FEED:0000.0005/input/input15
[  194.674020] input: Clockwork uConsole Keyboard Consumer Control as /devices/platform/axi/1000480000.usb/usb1/1-1/1-1.1/1-1.1:1.1/0003:FEED:0000.0005/input/input16
[  194.674201] input: Clockwork uConsole Keyboard as /devices/platform/axi/1000480000.usb/usb1/1-1/1-1.1/1-1.1:1.1/0003:FEED:0000.0005/input/input17
[  194.742231] hid-generic 0003:FEED:0000.0005: input,hidraw1: USB HID v1.11 Mouse [Clockwork uConsole Keyboard] on usb-1000480000.usb-1.1/input1
[  194.743683] hid-generic 0003:FEED:0000.0006: hiddev96,hidraw2: USB HID v1.11 Device [Clockwork uConsole Keyboard] on usb-1000480000.usb-1.1/input2
[  214.331625] v3d 1002000000.v3d: MMU error from client PTB (1) at 0xafb64c00, pte invalid
The CM5 lite is real picky with sd cards. The power button wont work for forced shutdowns if the kernels not loaded. The TEAMGROUP PRO+ sd cards seem to work well, I bought some but I don’t have lite to test with yet. I think we need to make a spreadsheet or wiki for the known working and nonworking cards.
I found out that when after the boot loader is initialized and then the SDCard is inserted, it will boot normally.
So I flashed EEPROM with the settings below so that the bootloader could detect SDCard repeatly.
[all]
BOOT_UART=1
BOOT_ORDER=0xf1
SD_BOOT_MAX_RETRIES=-1
POWER_OFF_ON_HALT=1
WAKE_ON_GPIO=0
It’s a temporary method, but I was able to boot for sure. It seems that the bootloader needs some treat from rpi devs. :slight_smile:
In addition, it seems that the hardware requirements for the SDCard of CM5 Lite and CM4 Lite are different.
The internal pull-up resistance of the CM5 Lite and the external board pull-up resistance of the CM4. There is an ambiguous explanation on the data sheet.
https://forums.raspberrypi.com/viewtopic.php?t=382129#p2283847
CM5 Lite
CM4 Lite
In my opinion (I’m not H/W engineer), to use CM5 Lite, we need to mod our uConsole board. (Or just look for available SDCards)
yes the sd card seemed to be working correctly. I got the 128gig
@paragonnov Good find, we can add that to the fixes for the more adventurous users. I’ve started a list of reported working sd cards. I think a working sd will be the easiest route for most users.
I used the TEAMGROUP PRO+ SD cards for testing as well. I still had occasional Bootloader errors. I tried some very expensive filming cards, and some very cheap “pack in” cards. I had issues with all of them.
I’m not disagreeing that the card makes a difference. Speed perhaps? But I think there is something else going on. Especially with the patterns of reboots vs cold starts. And the card always booting correctly the first time but not on subsequent starts. I am trying to figure out if there is something related to the partitioning that is happening when the card is expanded. Maybe the size of the card is more important than the speed. Not sure yet.
I wish the bootloader errors were a little more specific.
FYI, I’ve had zero boot issues on my pi 5 devterm when using an official raspberry pi tested SD card.
https://www.raspberrypi.com/products/sd-cards/
I got mine from one of the official Canadian dealers. I imagine there are American ones as well.
Well that’s not good, I was hoping it was a class or speed issue with them. We might have to do the custom EEPROM settings for it to be reliable.
I confirmed that SD_PWR_ON is HI, SDCard was turned off when I set SD_PWR_ON to LO.
It seems the hardware is not a problem so.
